Real Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-13-2014, 05:27 PM   #1
Rewards Points: 578
Real hardwood floor
I want to replace the carpet in the bedrooms to real hardwood floor of tiger wood (to match the wood floor in the living room).
I talked to a flooring guy about it. He said that although he would use real tiger wood at the top, he would use engineered wood under the real wood. Reason is that he believes I have concrete floor, and real wood doesn't stick to the concrete. Is that true?
HomeLearner is offline   Reply With Quote
Old 11-13-2014, 05:41 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Could be true. Has anyone done any moisture testing? Don't have any way to know without moisture tests.
How is it the "engineered wood" (I assume that means plywood) will stick to the concrete but the hardwood flooring product won't?
What exactly is his planned method of installation for these products?
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
joecaption (11-13-2014)
Old 11-13-2014, 05:44 PM   #3
Rewards Points: 578
Why do moisture tests?
I also wonder if it's the right time to do the wood floor. Wood expands in the summer but shrinks in the winter. Don't know how that may affect the way the wood is placed (in the winter season).
Old 11-13-2014, 05:45 PM   #4
Rewards Points: 578
I don't know much about flooring. I'll need to research on these subjects before asking him these questions.
Old 11-13-2014, 06:19 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 400
Before you install any type of flooring, but especially for wood, you need to know if any moisture is coming through the slab.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-13-2014, 06:22 PM   #6
Rewards Points: 578
Shall I call a home inspector to find out about moisture level? Would the inspector need to tear apart the carpet to test moisture?
Old 11-13-2014, 06:25 PM   #7
Rewards Points: 578
I have real hardwood floor in my living room. They look good. Isn't it an indication that the moisture level is fine?
Old 11-13-2014, 06:35 PM   #8
Rewards Points: 18,384
Engineered wood is real wood, it's plywood under a layer of veneer wood over it.
His plan makes 0 since to me.
Old 11-13-2014, 06:51 PM   #9
ZZZZZ's Avatar
Rewards Points: 1,338
Why not float the engineered wood floor? Use an underlayment with a moisture barrier
Like this stuff: http://www.homedepot.com/p/Roberts-A...-105/202299502
ZZZZZ is online now   Reply With Quote
Old 11-13-2014, 08:45 PM   #10
Rewards Points: 149
Find the floor you want and look up the manufacturer's recommendation for installing it over concrete.
LVDIY is offline   Reply With Quote
Old 11-13-2014, 08:48 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 17,740
Hell no.....he is one of the last people you would want to take advice from on something like this.
Call another flooring company and get their opinion. Don't tell them you have talked to anyone else.
ddawg16 is online now   Reply With Quote
Old 11-13-2014, 09:28 PM   #12
Rewards Points: 578
I might have mis-understood him. He did mention that engineered wood was real wood, if I recall. He might have meant using engineered wood.
Old 11-13-2014, 09:35 PM   #13
Rewards Points: 578
Good idea.
But where can I find the floor I want? In a home improvement magazine?
I want to match the floor in my living room. But I don't have the information about the manufacturer of the tiger wood and don't know how to get it, either.
I don't know if the original builder manufactured the hardwood or the previous condo owner hired a flooring company (after the condo was built).
Old 11-13-2014, 09:37 PM   #14
Rewards Points: 578
Good suggestion!
I can use this as an interview question when looking for a good flooring company.
Old 11-14-2014, 03:41 PM   #15
Rewards Points: 578
I called a flooring guy and told him that I would like to take a look at the work he did before in person (instead of photos).
He said he didn't feel comfortable to get me to his former clients' homes to see their floors.
Is it an unreasonable request to see the real work in person (instead of photos)?
Hardwood Floor Buckling klappjack Flooring 6 10-04-2014 12:21 PM
vinyl tile over hardwood floor??? DIY_GUY_419 Flooring 10 10-01-2014 02:42 PM
Sanding methods for uneven hardwood floors inquisitiveblue Flooring 3 08-05-2011 11:49 AM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 11:16 PM
