Re-Installing Oak Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 10-07-2015, 06:14 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 17,718
I'm about ready to start putting down my old oak flooring. Typical 1950's stuff.....1/2" thick T&G boards...about 2" wide.
The original house had the oak nailed on top of 1x6' boards ran diagonally. No vapor barrier.
My new sub-floor is the same 1x6's with 3/4" T&G plywood on top (long story)
When I did the bamboo upstairs...1 1/8" T&G sub-floor...and per manuf instructions, put down a vapor barrier (tar paper in my case)
Do I put down tar paper in this case?
I'm guessing I do.
Old 10-07-2015, 10:56 PM   #2
Rewards Points: 368
Yes I would suggest using a vapor barrier. Tar paper will do. We generally use AquaBar B which is a great product.
Awoodfloorguy is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Installing a basement subfloor around floor drains temetnosce Remodeling 3 08-06-2012 05:40 PM
Installing floor in family room with high ceiling. jrwilkinsonjr Building & Construction 1 05-08-2011 03:00 PM
Basement Floor Variance Allowance When Installing Ceramic Tile june New Member Introductions 0 10-26-2010 11:09 AM
Question on installing floating hardwood floor loragail Flooring 7 10-23-2006 10:06 AM
