Raising Floor 1/8 Inch - Flooring - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 08-26-2017, 02:16 PM   #1
Rewards Points: 12
Raising floor 1/8 inch
First time posting, so thank you in advance for the help!
I am getting ready to tile two small connected rooms with 12x24 gauged slate tiles. Both rooms have solid sub-floors (3/4 ply), but the sub-floor is 1/8" higher in one room (one room was an addition and had different flooring which hid the difference before). What is the best way to bring the lower floor up 1/8" before I install the cement board?
I have looked at using Ditra (or a similar membrane), 1/8 plywood sheets and 1/8 cork roll, but I wasn't sure which was the best and most cost efficient. The space I need to raise is only only 10.5'x4.5' so I'd prefer not to have to buy a big expensive roll of something that I probably won't ever need to use the rest of.
Birch McMullin is offline   Reply With Quote
Old 08-26-2017, 05:37 PM   #2
47_47's Avatar
Rewards Points: 320
Re: Raising floor 1/8 inch
The tile store I deal with carries backer board in 1/8" increments.
47_47 is offline   Reply With Quote
The Following User Says Thank You to 47_47 For This Useful Post:
Birch McMullin (08-30-2017)
Old 08-27-2017, 09:38 AM   #3
Rewards Points: 12
Thanks! I'll see if I can find a store that sells 3/8" backer (I'm using 1/4" in the other room).
Old 08-27-2017, 11:03 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,970
3/4 ply is not really considered strong enough for slate tiles.
jlhaslip and Nealtw like this.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-27-2017, 02:05 PM   #5
47_47's Avatar
Rewards Points: 320
Good catch by Rusty. Sorry op, missed the fact you are going with slate on 3/4" subfloor. You should add plywood to stiffen the floor. You could make up your 1/8" with the ply.
Listen to pros like Rusty for proper methods.
MTN REMODEL LLC likes this.
Old 08-27-2017, 10:18 PM   #6
Rewards Points: 12
Thanks. How much additional plywood should I add? Would using 1/2" backer (instead of 1/4") help? I'm trying to avoid adding too much thickness, since that floor is already going to be a little higher than the flooring in the rest of the house.
Old 08-28-2017, 01:30 AM   #7
jlhaslip's Avatar
Rewards Points: 708
What is your joist spacing? That affects the floor and subfloor stiffness.
I rarely see tile on anything less than 1 1/4 inch subfloor thickness.
Nealtw likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
Old 08-28-2017, 07:14 AM   #8
1 1/4 is the minimum.
The Following User Says Thank You to rusty baker For This Useful Post:
Old 08-28-2017, 08:43 AM   #9
Rewards Points: 12
Joist spacing is 16". Does the 1 1/4 include the backer board or do I need 1 1/4 of ply and then backer on top of that?
If I do 1 1/4 of ply, could I do Ditra (or similar product) instead of backer board to reduce the height a little bit? It looks like Ditra is easier to install too and might be more waterproof in a space that is going to be mudroom, laundry and pool bathroom.
Nealtw likes this.
Old 08-28-2017, 12:21 PM   #10
Rewards Points: 4,268
Backer board is not considered structural so adding thickness does not affect the ability of the floor to hold a tile. FWIW, natural tiles like your slate require about twice the stiffness in the subfloor as do porcelain and ceramic and then also come with the maintenance of needing to be sealed. I would be considering a different tile, personally.
stick\shift is offline   Reply With Quote
The Following User Says Thank You to stick\shift For This Useful Post:
Old 08-28-2017, 01:31 PM   #11
There should be a chart on the John Bridge forum telling you what you need.
Old 08-28-2017, 05:11 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 754
Hi Birch,
As mentioned, natural stone tiles require a much stiffer subfloor system than ceramic tiles do. By system, I mean both the framing and the subfloor. Simply, you need another layer of 1/2" min. underlayment-grade ply properly installed then you can install Ditra to save height.
But we need to start with the framing. Tell us the; size of your joists, if you can determine the species and grade, that would help. Measure the unsupported span of the joists. We already know the spacing is 16" oc. Waiting for your reply.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
The Following 2 Users Say Thank You to JazMan For This Useful Post:
Birch McMullin (08-30-2017), rusty baker (08-29-2017)
Old 08-30-2017, 03:20 PM   #13
Rewards Points: 12
Hi Jaz,
The joists are 2x10s (1.5"x9.25"). I believe the unsupported span is 11' or 11'6". If necessary, I could cut another section out of the floor to be sure. I don't see any markings on the wood to indicate species or grade, but they look like pressure treated (sort of yellowish-greenish tint) and look like they're in really good shape. I can only see two joists (one side each) though. Is there a trick to determining species if I'm not a pro at identifying wood?
Thanks!
Birch
Last edited by Birch McMullin; 08-30-2017 at 03:21 PM. Reason: remove text from previous post
Old 08-30-2017, 03:27 PM   #14
retired framer
Rewards Points: 234
If you get real lucky there is a stamp about 2 ft from one end on one side.
If they were 12 footers it would still be there but it could be turn away from you because of crowning they get turned over.
Nealtw is offline   Reply With Quote
The Following User Says Thank You to Nealtw For This Useful Post:
Birch McMullin (09-01-2017)
Old 09-01-2017, 06:07 PM   #15
Rewards Points: 12
Is it worth cutting out another section of plywood to look for the stamp?
Tags
flooring
How to lay hardwood Maple 2 1/4 inch to allow for expansion TNDIYer Flooring 0 02-16-2016 11:52 PM
Raising Concrete Floor 1 Inch Toilet Bowl Flooring 2 08-02-2012 07:20 PM
Can I take out a load bearing wall (kitchen -living room) and use a 22 foot using 10 inch x 5/8s plate stell with 7 inch flange on bottom allanearle Building & Construction 2 05-09-2012 08:46 PM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 12:19 PM
24 inch to 16 inch Centers dsearles Building & Construction 3 11-30-2005 11:20 PM
