Radiant Floor Heating In Bathroom. No Sensor... - Flooring - DIY Chatroom Home Improvement Forum
Old 10-22-2014, 03:24 PM   #1
Rewards Points: 20
Radiant floor heating in bathroom. No sensor...
Big problem. I installed a radiant floor wire in my bathroom leveled and tiled then realized I forgot to put in the temp sensor. How big of an issue is this? Do I have to break out some tiles and install it.... Can I leave it dangling off the sensor and just use It on a timer?
shiftline is offline   Reply With Quote
Old 10-22-2014, 06:43 PM   #2
Rewards Points: 1,910
I would think that the sensor would provide much better heat control than a timer. You put in radiant so you'd have a nice consistent warm floor for your feet. Without the sensor it's going to be too cold or too hot instead of that "aaaahhh" just right feeling. Why put in the time , money and effort and not get the desired goal?
I'd figure out a way to pop out a tile or two and install it.
Old 10-22-2014, 10:23 PM   #3
Rewards Points: 20
True enough. I'll try removing a smaller tile and hopefully placing it under. Hopefully it will Safice
Old 10-22-2014, 10:37 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Wood or concrete subfloor?
XXX
Old 10-22-2014, 10:54 PM   #5
Rewards Points: 20
Conceete. I broke yes tile out and will pop it underneath. And cut a groove in drywall for the wire. May be a few degrees off but atleast it will be adjustable
Do I need to thinset a new tile in or can I just use Pl400 and grout it?
Old 10-22-2014, 11:01 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You need the mortar (thinset in this case) this is your thermal-transmitter. Use thinset. The wires are only capable of transmitting heat about one-and-one-half-inches on either side of the wire via the mortar. Same goes for the sensor receiving the heat information. PL400 will just screw things up.
XXX
Old 10-22-2014, 11:09 PM   #7
Rewards Points: 20
Okay. Thank for the tips. The sensor should hopefully be about 1/4" ish above the wire as they were just covered in self levelling compound.
Old 10-23-2014, 11:47 AM   #8
Rewards Points: 20
All fixed. Minus the grout.
Thanks for the motivation to do it right
bathroom exhaust connected to 26' of duct ChrisJJ HVAC 1 01-31-2013 11:50 AM
Radiant Heat - Floor Sensor Placement dajate Flooring 2 12-29-2012 09:29 PM
Outdoor Motion Sensor troubles LCBoomer Electrical 2 12-01-2012 07:20 PM
Extending or Modifying Wireless sensor for Tstat kilosos2 HVAC 4 04-15-2012 02:17 PM
3-way switches, lights, and a photoelectric switch. Your thoughts? Fox Electrical 7 11-23-2010 11:08 AM
