Radiant Floor Heading On Existing Concrete Slab And Insulation - Flooring - DIY Chatroom Home Improvement Forum
Old 10-07-2014, 10:39 AM   #1
Rewards Points: 20
Radiant floor heading on existing concrete slab and insulation
I'm installing a floor heating system in a downstairs bathroom on concrete slab. The manual recommends insulating the floor to make it more efficient. What would the the best/thinnest insulation to use?
The rest of the House is 15mm laminate. The bathroom will be large format travertene and the floor will already be raised when o slef level it to burry the heating wires so if I do insulate it needs to be reasonably thin.
Is it with doing if so any suggestion on what to use?
shiftline is offline   Reply With Quote
Old 10-07-2014, 02:16 PM   #2
Rewards Points: 17,912
Insulating a slab is done before the slab is pore with foam under the slab, little late now.
You do know travertine is a porous soft tile and a poor choice for a bathroom, right?
Old 10-07-2014, 02:56 PM   #3
Rewards Points: 20
Wouldn't sealing it deal with the porous issue? Or is it still my recommended. It's on sale for pretty cheap right now and seems like a good option
Old 10-07-2014, 03:10 PM   #4
http://buildipedia.com/at-home/floor...-tile-flooring
Build house on existing concrete slab troyman Building & Construction 6 04-21-2014 05:05 PM
Radiant Heating on a Concrete Slab MikeDobbs Flooring 9 05-27-2012 12:33 PM
How do I install insulation to floor joist setting on a concrete slab TimmyP Building & Construction 6 01-25-2011 11:53 AM
Insulating an existing floor over a concrete slab rbo Flooring 1 12-06-2010 05:41 AM
edge insulation on slab for radiant heat crankcase General DIY Discussions 5 10-05-2010 11:49 PM
