Quikrete Ready-to-Use Concrete Mix - Flooring - DIY Chatroom Home Improvement Forum
Old 12-09-2014, 02:23 PM   #1
Rewards Points: 154
Hi All,
Would it be OK to use Quikrete concrete mix to resurface my basement floor which concrete with a lot of imperfections?
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
I know Quikrete has a specific fast-setting resurfacer, but it costs 10 x's more than the link above.
Just doing my initial due diligence before I go one way or another.
llckll is offline   Reply With Quote
Old 12-09-2014, 02:27 PM   #2
Rewards Points: 18,376
Not going to work, it's full of stones as a filler.
Old 12-09-2014, 02:33 PM   #3
Rewards Points: 154
Thanks.
Old 12-09-2014, 05:05 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Originally Posted by llckll View Post
Hi All,
Look at using Self Leveling Compound.
XXX
Old 12-09-2014, 08:31 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
Hi All,
Technically yes you can, but it's more meant for vertical walls as well as walk ways ect. You would never be able to trowel and float it completely even for just a cover coat.
I would go with SLC as Bud pointed out.
JetSwet is offline   Reply With Quote
Old 12-09-2014, 09:44 PM   #6
Rewards Points: 1,042
Just be aware there are two kinds of slc's, one for underlayment and one for topping, be sure to get the right one for your application.
Canarywood1 is offline   Reply With Quote
Old 12-11-2014, 02:35 PM   #7
Rewards Points: 5,010
What kind of imperfections.?
ron45 is offline   Reply With Quote
Old 12-11-2014, 05:19 PM   #8
Pro
JetSwet's Avatar
Rewards Points: 502
Huh?....
Tags
basement , cement , quikrete , resurface , subfloor
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 10:08 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
