Prepping Concrete For Ceramic Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 06-28-2014, 12:15 PM   #1
Rewards Points: 41
I am prepping the bathroom concrete floor to lay ceramic tile. The previous tile had a cork underlayment. After removing tile and underlayment, I am left with a residue. Would I be okay just using a floor scrapper to get as much up as possible, or should I rent a floor sander to really get it up? Thanks!
[IMG][/IMG]
[IMG][/IMG]
slappydan is offline   Reply With Quote
Old 06-28-2014, 12:16 PM   #2
Rewards Points: 41
http://i829.photobucket.com/albums/z...4CE959A29D.jpg
Old 06-28-2014, 12:32 PM   #3
Retired Moderator
Rewards Points: 7,174
Use a razor scraper---do not use any chemicals--they will soak the slab and cause a bond breaker---If that fails--a hand held angle grinder fitted with 60 grit sand paper or a diamond grinding cup will work--
Old 06-29-2014, 12:08 AM   #4
Rewards Points: 41
Awesome! Thank you.
The Following User Says Thank You to slappydan For This Useful Post:
oh'mike (06-29-2014)
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Tile on concrete flooring preparation nanllyn Flooring 1 12-21-2011 02:22 AM
Tile over concrete Kathompson Flooring 0 07-30-2011 08:24 PM
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 08:11 PM
Prepping concrete subfloor for laminate ehuesman Flooring 5 11-28-2007 11:28 AM
