Prep Before Oil Finish On White Oak Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 01-21-2019, 11:31 PM   #1
Rewards Points: 132
Prep before Oil Finish on White Oak Stairs
Set of white oak stairs that Im going to finish with Rubio.
Theyve got some traffic on them during construction so Im wondering what the best prep is before sanding then w/ 80, vac, tax cloth, apply rubio?
Should I be hitting them with some sort of cleaning solution first?
Vanner is offline   Reply With Quote
Old 01-22-2019, 05:36 AM   #2
retired painter
Rewards Points: 1,712
Re: Prep before Oil Finish on White Oak Stairs
Hard to say without seeing them but unless they got stained with something out of the ordinary - sanding should be sufficient.
mark sr is online now   Reply With Quote
Old 01-22-2019, 07:14 PM   #3
Rewards Points: 132
Couple spots with some water marking. Other than that, just foot and hand grime.
Old 01-23-2019, 05:26 AM   #4
retired painter
Sanding should be enough although if the water stain goes too deep you might need wood bleach.
Old 01-27-2019, 11:46 PM   #5
Rewards Points: 368
I use a lot of Rubio and I can tell ya that sanding will be good. However, I would sand them up to 100 or 120 grit to be sure you get out all sanding marks. Hope this helps.
Awoodfloorguy is offline   Reply With Quote
Need advice on how to finish stairs cline052 Carpentry 7 03-15-2015 10:46 AM
How to finish basement stairs mark2741 Flooring 9 11-13-2012 12:09 AM
Does white always need multiple coats? NWFixer Painting 16 07-31-2012 07:40 AM
How would you finish these stairs? Sammyc53 Building & Construction 9 10-12-2010 08:52 PM
cream trim downstairs, white trim upstairs, advice for stairs? allyr Painting 1 09-26-2009 04:01 PM
