Porcelain Wood Tile Question - Flooring - DIY Chatroom Home Improvement Forum
Old 01-05-2019, 07:21 PM   #1
jb9
Rewards Points: 198
Hello,
I am getting ready to tile my bathroom (wet room actually) with porcelain wood tiles. I don't know much about tiling a wall with this material. Are there any things I need to be aware of using this kind of tile in a bathroom? My backer board and substrate will be Schluter Kerdi.
Thanks in advance.
jb9 is offline   Reply With Quote
Old 01-05-2019, 08:07 PM   #2
retired framer
Rewards Points: 20,734
Re: Porcelain Wood Tile Question
Triple check the floor for level if it is out, start the wall at the lowest spot so you can trim tile and maintain level.
The Following User Says Thank You to Nealtw For This Useful Post:
jb9 (01-05-2019)
Old 01-11-2019, 10:44 AM   #3
Rewards Points: 4
I did this; If you want it to resemble actual wood, use the smallest possible spacers for thinner grout lines and select a grout color that is closely matched to the tile color.
amalejko is offline   Reply With Quote
Old 01-12-2019, 04:49 PM   #4
Tile store owner
Rewards Points: 4
Porcelain Wood tiles have come so far that they are starting to mimic the real thing with the 3D printing they offer. A tighter grout joint and also a grout that closely matches will be a great start.
mikebelk is offline   Reply With Quote
Tile to wood floor transition stupid48 Flooring 2 02-18-2013 11:31 AM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
another tile question: installing large (1'x2') porcelain wall tiles diy'er on LI Tiling, ceramics, marble 4 09-16-2009 01:57 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 09:22 PM
