Porcelain Tile Over Linoleum - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By oh'mike
  • 1 Post By MrElectricianTV
Old 05-29-2016, 12:23 PM   #1
Rewards Points: 8
porcelain tile over linoleum
I'm starting to plan a remodel for my laundry room. The current flooring is linoleum glued to the concrete basement slab. I would like to put down porcelain tile over the lino, is that okay to do? Also we were going to run the tile out of the laundry room into the entry way that comes from the garage. There is a small lip where the lino and concrete meet and wasn't sure if that will effect leveling the tile. I've attached a few photos to help show what I'm referring to.
porcelain tile over linoleum-image-5-.jpg   porcelain tile over linoleum-image-6-.jpg   porcelain tile over linoleum-image-4-.jpg
rt520 is offline   Reply With Quote
Old 05-29-2016, 02:49 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: porcelain tile over linoleum
If possible, strip out the old sheet goods----tile can be bonded to vinyl --however, it is a risky installation.
If the vinyl is a sponge backed one--then it MUST be removed--
Use a two part thinset--Kerabond and Keralastic is a good example of that type---
I do not recommend tiling over sheet vinyl--
de-nagorg likes this.
Old 05-29-2016, 04:43 PM   #3
Rewards Points: 2,076
I would check with the thinset manfacturer and the tile manfacturer. I gather you are trying to avoid extra work by not removing the linoleum. I think that you will be better off with a cement backing instead of a linoleum backing.
My father had three layers of linoleum and vinyl tile on his kitchen floor. After we we cleaned out his house I noticed that the top floor tiles had all moved. There were gaps up to a 1/2" between some of the tiles. I surmised that floor layering is not a good thing.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Old 05-30-2016, 09:45 AM   #4
Rewards Points: 8
Yes that is exactly what I was hoping to avoid. Also the house was built in 1978 so there is a possibility that there could be asbestos in it. If I was able to cover it I could save the cost of having it tested as well as having to be removed.
Thanks for the responses!
Old 05-30-2016, 11:06 AM   #5
Retired Moderator
Removing asbestos flooring is something you can do safely---no need to 'hire a specialist'--
Keep it wet as you scrape--no dust will be stirred up.
Old 05-30-2016, 04:53 PM   #6
I am old school. I would just put a mask on and rip it out.
John Grabowski
MrElectrician.TV
Old 05-30-2016, 07:36 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,668
Bad idea.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Tile to Linoleum to Tile greentrees Tiling, ceramics, marble 12 08-13-2013 09:24 PM
tile over linoleum merlin66043 Tiling, ceramics, marble 4 02-18-2013 05:15 PM
Installing Porcelain tile, complete guide? Total Sugar Flooring 5 03-07-2011 09:22 PM
New porcelain tile to replace vinyl floor in kitchen PatrickGSR94 Flooring 5 03-03-2011 01:42 PM
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 07:11 PM
