Porcelain Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 11-17-2013, 11:13 PM   #1
n2omichael's Avatar
Rewards Points: 115
Porcelain tile
I Have a small cottage that is 2 storey, on the top floor entrance way I would like to use a combination of hardwood and porcelain tile, however I have been told that ANY tile, ceramic, marble, slate or porcelain will crack if the building isn't heated year round. I have had others tell me that depending on which tiles, and what grout you use it CAN be done?
The room is only about 20 x 6 (120 sq ft) and I still have to carve a hole for a staircase out of that, so, I don't mind having to spend a little extra for a special grout or tile since it's such a small area.
ANY input or suggestions are appreciated!
Michael
n2omichael is offline   Reply With Quote
Old 11-17-2013, 11:27 PM   #2
Rewards Points: 1,002
There is plenty of tile which is installed outdoors where temperatures drop below freezing.
I have some bakeware which I regularly bake with and also freeze stuff in it.
I would be more concerned with a wood floor getting extremely dry with heat and NO HUMIDIFIER than with a low temperature and some natural humidity.
In conclusion, the concern about tile and freezing temps is unfounded.
A porcelain tile will be best in any condition and a urethane grout will have a bit of flexibility.
Now, lets talk about the belly of the space shuttles...
cleveman is offline   Reply With Quote
Old 11-17-2013, 11:35 PM   #3
n2omichael's Avatar
Rewards Points: 115
I "get" the space shuttle comparison, but, the tiles on the shuttle aren't grouted in place I didn't think? I was told there where held in place with an expandable composite, not "grout"
Hey, when I said I didn't mind spending "A little extra money" I didn't mean it could afford the tiles off the shuttle!! Ha Ha
Do you think I should leave a small gap between the hardwood and the tile? I wondered if the wood might expand and contract differently than the tile, and could "push" on the tile and crack it?
It's all new to me so I sure appreciate the info, and please keep it coming, Thanks!
Old 11-18-2013, 12:39 AM   #4
You sure want to leave a space between the wood and the tile. They will probably spec 1/2" or 3/4" and most people leave 1/4".
Leave as much as you can cover with your trim.
Marble vs. Porcelain Tile DrDIYer Flooring 11 10-02-2017 04:58 PM
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 10:32 PM
Porcelain Tile ssgtjoenunez Flooring 24 02-16-2013 02:31 PM
Installing Porcelain tile, complete guide? Total Sugar Flooring 5 03-07-2011 10:22 PM
Subfloor and Porcelain tile prep sugarhousemama Flooring 4 12-03-2010 07:47 PM
