Plywood Underpayment Over Original Wood Plank - Flooring - DIY Chatroom Home Improvement Forum
Old 03-24-2018, 11:22 PM   #1
Rewards Points: 4
Plywood underpayment over original wood plank
Iím going to install Mannington vinyl floor snap together panels and Iím starting with a half inch ACX plywood subfloor over the original 1940s wood plank. I have a couple of questions. Do I need to glue the underlayment down? And do I need to switch up the grain between the subfloor and the original floor i.e. running in opposite directions? Thanks in advance for your answers and input
Eric
Eric99223 is offline   Reply With Quote
Old 03-25-2018, 01:27 AM   #2
Rewards Points: 4
Ok..
A little more info. It's AC plywood not ACX and it's in a kitchen and dining room.
Old 03-25-2018, 06:39 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 4,182
Re: Plywood underpayment over original wood plank
Good plan. Don't glue the second layer, and install your fasteners intentionally missing the joist system. I would first secure the planks to the joists to prevent movement and possible squeaks later on. You still run the grain of the plywood across the joist system, perpendicular to the joists.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
rusty baker (03-27-2018)
Old 03-25-2018, 08:45 AM   #4
Rewards Points: 4
Ok.. that leads to two questions I was planning on running across the grain of the original planks but that would be with the floor joists. So wondering what the reasoning is there? And I have seen several posts here and elsewhere saying to avoid the joists when screwing down. Why is this?
E..
Old 03-25-2018, 08:51 AM   #5
Naildriver
chandler48's Avatar
Don't worry about the old subflooring. You want your second layer to go across the joists, with the grain of the planks.
Even though it is minimal all things move. If you stiffen the two layers of subflooring by attaching them both to the joists, you prevent this natural movement. That is why no glue, also. Let things move and you'll have less squeaks, too.
Larry......
Old 03-25-2018, 10:39 AM   #6
Rewards Points: 4
Ok I understand. Thank you!
Old 03-26-2018, 07:13 AM   #7
Rewards Points: 4
Ok one more question popped up. When I get the new underlayment down (19/32 a.c. external) should I take the extra step and seal it? It is in the kitchen and the snap vinyl is listed as water resistant not waterproof.
E..
Old 03-26-2018, 03:58 PM   #8
Naildriver
chandler48's Avatar
You can, but I don't know what you have in mind for a sealer. What is "external"?
Larry......
Old 03-26-2018, 08:39 PM   #9
Rewards Points: 4
My bad exterior...Lol no idea what I would use as a sealer. Just thought about some floor sealer from the local box store
Old 03-27-2018, 04:34 AM   #10
Naildriver
chandler48's Avatar
Don't use pressure treated plywood on the interior of a house, if that is what you mean by "exterior".
Larry......
Old 03-27-2018, 04:36 AM   #11
Rewards Points: 4
Not at all. It just says exterior. Anyway I'm thinking of something like redguard
Old 03-27-2018, 05:22 AM   #12
Naildriver
chandler48's Avatar
$54 a gallon , think Zinsser Bin Primer oil base.
Larry......
Old 03-27-2018, 08:03 AM   #13
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,632
E..
All wood contracts and expands. If you glue it down or fasten it to the joists, it may split when it expands or contracts. That could lead to a lot of problems.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-02-2018, 08:18 PM   #14
Rewards Points: 26
if the wood floor under the ply is solid the you can screw to that make sre the screws are at least 1 inch longer then the ply I put them about every 6 inches and ply really doesn't have a grain . Have done quit afew and have never had a problem
chris121244 is offline   Reply With Quote
Replace plank subfloor with plywood Hammerswinger General DIY Discussions 12 01-24-2017 08:29 AM
why do i need to paint my house? homie Painting 17 07-04-2015 02:04 PM
Wood Plank Shower Floor carter72 Kitchen & Bath Remodeling 12 04-26-2015 07:02 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
