Pine Floors Problem Needing Creative Solution - Flooring - DIY Chatroom Home Improvement Forum
Old 02-25-2015, 11:58 AM   #1
Rewards Points: 2
pine floors problem needing creative solution
We need a 'quick fix' to get ready to sell our house.
We have a 4 yr old house with pine plank floors that were polyurethaned (unstained). They now look like this:
What can we do to fix these divots/scratches/dents and greyed wood (that happened from water getting on exposed pine) without sanding the entire main floor of the house? We are concerned that sanding just the affected areas will result in much lighter boards.
vjodoin is offline   Reply With Quote
Old 02-25-2015, 12:55 PM   #2
Rewards Points: 17,912
There is no quick fix for that one, there long over due to be sanded and sealed.
Old 02-25-2015, 12:59 PM   #3
Rewards Points: 144
Four year old house?You may have bought the house four year ago?That is rust from the nails where the floor was face nailed.You can set the nails with a nail set and fill the holes but the only way you can fix that floor is with a total sand and refinish.
mako1 is offline   Reply With Quote
Old 02-25-2015, 01:46 PM   #4
Rewards Points: 107
I would just compensate the buyer at closing for refinishing the floor. It is much easier and faster to refinish in an empty house and the buyer can have it done before he moves in. There is no easy fix for this .
jimn01 is offline   Reply With Quote
Furnace problem...solution per contractor...please take a look gone_fishing HVAC 5 12-01-2008 05:40 PM
Polyurethane finish on hardwood floors problem Jeakes Flooring 1 08-04-2008 03:52 PM
Chimney has simple problem - complicated solution Leah Frances General DIY Discussions 6 03-18-2008 04:52 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 07:06 AM
Simple problem that requires a complex solution. wfischer Electrical 18 01-07-2008 12:21 PM
