Pergo Installedon Top Of Pergo - Flooring - DIY Chatroom Home Improvement Forum
Old 09-18-2015, 01:25 PM   #1
Rewards Points: 16
Pergo installedon top of pergo
Good day gents
I have a basement with pego on top of a vapor barrier foam underlyment
Can I put a new pergo floor on top of the original
I'm aware that this means cut in in doorways
Thx!
sakskc is offline   Reply With Quote
Old 09-18-2015, 01:33 PM   #2
Rewards Points: 18,384
Why would you want to do that?
Makes a lot more since to just remove the old first.
Old 09-18-2015, 02:06 PM   #3
Rewards Points: 16
Removing the old does make sense but there is a catch
Since its install there were a few dividing walls added and they were framed on top of the floor
I can cut along the floor to free them which I'm good to do but I need a good tool option for this
Since it is parallel to the wall a tangent cut is best, but all I have is a roto-zip
Any suggestions?
Thx sk
Old 09-18-2015, 02:19 PM   #4
Rewards Points: 5,348
Any suggestions?
Thx sk
You are not supposed to put any structure on these floors. You don't put kitchen cabinets on them, much less a wall.
You can do the correct installation or you can continue on the road to, "questionable building practices".
Ron
B. Franklin 1759
Old 09-18-2015, 04:22 PM   #5
I use a Toe Kick Saw to cut floors out that are run under walls.
I agree, huge no no to install a wall on top of laminate.
Old 09-18-2015, 04:28 PM   #6
Rewards Points: 16
Thx I bought the house after the floor and walls were in, it is just obvious that one came before the other.
I noticed this after i started to review the job.
Thx
Old 09-18-2015, 04:49 PM   #7
Rewards Points: 7,603
One of the cheap ones from Harbor Freight should handle this with ease. A Roto-Zip is the completely wring tool to use.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 09-18-2015, 05:22 PM   #8
Rewards Points: 16
Excellent thx
Old 09-19-2015, 09:37 AM   #9
Rewards Points: 996
i have a harbor freight toe kick saw, it works well. but beware, if you are cutting flooring that is on top of concrete = letting the blade touch the concrete will dull the blade real quick.
also, be VERY CAREFUL , this saw has some kick to it and can turn very dangerous real quick. i would say this saw is more dangerous than a chain saw.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Colbyt (09-19-2015)
Pergo max or allure vinyl? aumanpj Flooring 4 09-02-2015 01:18 AM
Snap, crackle, pop...PERGO flooring!!! georgiabird Flooring 7 10-30-2012 04:29 AM
joining old pergo to new pergo zabejames Flooring 0 08-17-2011 02:38 PM
Question: Can I Install Pergo over Dri Core? Starlight Flooring 1 10-01-2010 09:05 PM
pergo prestige vs pergo accolade [email protected] Flooring 1 03-15-2009 05:06 PM
