Peeling Back Linoleum Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 11-09-2013, 10:18 AM   #1
Rewards Points: 251
I have to do a subfloor repair around a toilet and we're trying to avoid having to replace the entire linoleum floor. Any tricks to "peeling" it back without it tearing or crumbling so that I can just reglue it down? I've removed old linoleum flooring in the past and I'm thinking that the outlook on sparing the floor is pretty bleak… but, maybe somebody has a trick?
Heat gun? Clothes iron on a wet towel?
mikeyp78 is offline   Reply With Quote
Old 11-09-2013, 10:26 AM   #2
Rewards Points: 18,954
Sorry I just do not see that happening unless it was just perimeter glued which is not likely.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
mikeyp78 (11-09-2013), rusty baker (11-09-2013)
Old 11-09-2013, 06:28 PM   #3
Rewards Points: 251
I kind of figured. Thanks! Maybe I'll get lucky.
Seeking advice for repairing small tear in bathroom linoleum floor lonlonmilklover Flooring 3 01-10-2013 02:08 PM
Question about installing new vinyl flooring nschulz Flooring 2 06-18-2011 02:19 PM
can linoleum be painted? ADaniLion Flooring 0 06-12-2011 07:25 PM
Linoleum not flush against tub bottom? shub Flooring 5 05-31-2011 10:59 PM
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 03:13 PM
