Patch Joints On New Subfloor Under Thick Vinyl Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-14-2015, 12:29 PM   #1
Rewards Points: 4
patch joints on new subfloor under thick vinyl tile?
Hi all..
First time doing any vinyl tile.. Ive got ~50 sq feet to lay in my bathroom.. fairly thick and stiff (1/8-3/16?) 2' x 1' glue down vinyl tiles..
I was planning on screwing down some good one side 1/4" plywood and expect to have one joint in it, probably 2.5-3' long, out of the main traffic path..
The only floor leveller I can find in a couple local supply stores is a big bag of unmixed for ~$40, so Im not crazy about the idea that Ive seen in a couple web-writeups about having to patch and feather that one joint..
As long as I keep my joints tight, can I get away with not patching the joint?
thanks,
brett
bfraser is offline   Reply With Quote
Old 09-14-2015, 01:25 PM   #2
Rewards Points: 144
Is the 1/4" ply rated for underlayment?
mako1 is offline   Reply With Quote
Old 09-14-2015, 02:07 PM   #3
Rewards Points: 4
I honestly couldnt say.. As it was going down on top of an older beat up ply floor, i wasnt so worried about increasing rigidity but more making a smooth surface.. I could easily step it up to 1/2" if thats typical?
Old 09-14-2015, 04:30 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 548
I wouldn't screw the underlayment down. Screws will make it pucker, As far as the joint, I always patch them, but some guys don't. Seems to work out OK either way.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-15-2015, 01:15 AM   #5
Rewards Points: 144
My question about being rated for underlayment has nothing to do with rigidity.I f using regular 1/4" luan or something not rated for underlayment the laminations could fail or there may be voids in the sheets.
The Following User Says Thank You to mako1 For This Useful Post:
Colbyt (09-15-2015)
Vinyl shower walls, cut to size, glue to studs, caulk joints? gunner666 Kitchen & Bath Remodeling 4 07-16-2015 06:05 AM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Old flooring / installing new vinyl tile gwelton Flooring 2 06-24-2009 03:10 AM
Patch a hole in the bathroom tile sw41 Flooring 1 12-07-2008 12:57 PM
