'Passive' Wood Floor Restoration - Flooring - DIY Chatroom Home Improvement Forum
Old 05-17-2015, 09:37 AM   #1
Restoration professional
Rewards Points: 302
Has anyone done this technique? How does the cost and results compare to traditional drum sander + poly?
halliwellc is offline   Reply With Quote
Old 05-17-2015, 01:32 PM   #2
Retired Moderator
Rewards Points: 7,174
I've never heard of that method (at least by that name) -could you explain the process?
BigJim (05-17-2015)
Old 05-17-2015, 01:59 PM   #3
Rewards Points: 7,569
I have not purchased any of the expensive kits or chemicals.
I did go over about 500 square feet of still smooth wood which had a damaged water based poly finish using nothing but some parsons sudsy ammonia diluted with water water, a black stripping pad driven by a floor buffer. That was mopped up well and the floor rinsed twice with clean water. After drying well fresh poly was applied. The floors looked as good as the first time they were sanded and sealed.
One caution would be that you have to know what the previous finish was before proceeding.
I will defer my opinion to the flooring guys as theirs would be a more professional opinion.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 05-17-2015, 02:15 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 602
From what I am seeing there is only one company refinishing floors with that method and they don't sell anything so someone can DIY their floor themselves. Looks like with all the liquid they put on the wooden floor it could cause problems but it didn't seem too.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 05-17-2015, 03:38 PM   #5
Rewards Points: 18,382
Only way I would do that is if I was flipping a house for resale.
What it to hold up then sand and refinish.
Old 05-17-2015, 03:43 PM   #6
Rewards Points: 302
Why do you think it won't 'hold up'?
Old 05-17-2015, 06:11 PM   #7
Common since.
No finish is going to be able to bond to an old poly finish.
Want it to last do it right.
Old 05-17-2015, 09:31 PM   #8
Rewards Points: 302
Common since.
Passive floor restoration removes all the old poly finish chemically, instead of mechanically.
The Following User Says Thank You to halliwellc For This Useful Post:
oh'mike (05-18-2015)
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 06:20 PM
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
