Pad For Glued Engineered Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-17-2015, 01:28 AM   #1
Rewards Points: 48
Pad for Glued Engineered Floor?
I live in a two level condo in Northern California. I had an installation of an engineered hardwood floor start today. I elected to have it glued rather than use a floating floor, because I liked the solid feel underfoot.
A friend of mine who lives nearby had a similar installation recently, by a different company. She says that for her installation, which was also glued, a pad was used underneath. I asked the company a few weeks ago if a pad was required and they said no.
My friend has mentioned the pad again. Pretty sure based on what they've done so far they aren't using a pad. Do I need a pad? The condo floor is concrete.
- Doug.
dgarstang is offline   Reply With Quote
Old 12-17-2015, 09:30 AM   #2
Rewards Points: 18,382
Best advice, go on the company website that made the flooring and down load the install directions.
Did they do a moisture test before starting?
I've never seen a glued down floor installed over any form of pad.
What's up with those shims under the flooring, is it that far off from being flat?
Old 12-17-2015, 11:23 AM   #3
Rewards Points: 5,348
She may have put down a floating floor, not a glue down floor. Maybe her seams were glued, not the back to the pad. Gluing a laminated floor to a foam pad is bizarre. I have never seen or heard of another instance of this form of installation.
I can't see the adhesion being maintained over time.
Ron
B. Franklin 1759
Old 12-17-2015, 11:34 AM   #4
Rewards Points: 48
Thanks folks.
Ron6519, my floor isn't laminate. It's engineered hardwood. I'll definitely ask about the moisture check when they arrive today.
Doug.
Floating engineered wood floor over ceramic tile Camera Flooring 10 11-20-2013 06:30 PM
Engineered Wood Floor Removal? Bottlerocket Flooring 1 02-19-2013 08:02 PM
Sacrificial plywood underlayment before gluing engineered floor? chesterton Flooring 2 12-29-2012 02:17 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
engineered floor grainbelt Flooring 0 12-10-2009 10:55 AM
