Outdoor Carpet - Glue Perimeter Only? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-11-2015, 01:03 PM   #1
Rewards Points: 511
I'm placing outdoor carpet on a 14x20' concrete pad. Planning to only glue 4" around perimeter and at the seam. Is this typical install procedure, or does entire area typically get glued?
Also, is carpet typically placed on the visible side edge of the pad? What has to be done to hold it while it's curing. Thanks.
LarryJ-nova is offline   Reply With Quote
Old 12-11-2015, 02:55 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 780
If you only glue the perimeter, it's going to pucker, stretch and look bad. You could try perimeter tape and "fix" it as needed, or just do it right. Your location and the slab's exposure would be things we'd like to know too. OK,"nova" I think I know where you are.
Jaz
Sure would be nice if people would state their location when signing up to this forum.
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 12-11-2015, 03:04 PM   #3
Rewards Points: 511
I'm in Virginia Beach.
Slab has eastern exposure.
"do it right", meaning cover entire slab with glue?
I won't use tape.
Old 12-11-2015, 03:17 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 780
OK, Virginia Beach. We'll let you call that NOVA although it's 20 miles from the southern border.
Yes, I think full-spread is the way to go. Is the slab covered? Does it slope, drain well?
Jaz
Old 12-11-2015, 04:22 PM   #5
Rewards Points: 511
Jaz
What does my location in Virginia have to do with anything related to the installation of outdoor carpet. Come on, man!
Old 12-11-2015, 05:12 PM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
It matters on the adhesive to use and how long the carpet will last.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-11-2015, 05:27 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 780
LarryJ-from Nova,
You're kidding right? Do you think you'd get the same answer if you were anywhere on earth, it wouldn't matter? Also as the conversation continues, don't you see where the location, therefore the temp and humidity etc. would influence our answers?
It's obvious that the location makes a difference. BTW it's probably even more important when it's an indoor project. Can you imagine why?
Jaz
Old 12-11-2015, 08:28 PM   #8
Rewards Points: 18,376
I've never been paid to install indoor, outdoor carpeting on a patio but have been paid to try and remove it and the old glue dozens of times.
Just a very bad idea.
Want a soaking wet, hard to clean surface, going to fail floor that's the way to go.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
JazMan (12-11-2015), rusty baker (12-11-2015)
Old 12-11-2015, 10:08 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 780
Absolutely right Joe. I thought that fad went out with the '70's, '80's for sure, especially if exposed to the weather. Just after kitchen carpeting. Not a great idea, but definitely a cheap way to improve the looks of old cracked concrete temporarily.
Jaz
Old 12-12-2015, 09:41 AM   #10
Rewards Points: 511
snide comments aren't helpful at all. I'll be gluing the entire outdoor surface using the glue that the salesman in Home Depot recommended.
Old 12-12-2015, 10:31 AM   #11
Tileguy
JazMan's Avatar
Rewards Points: 780
There you go. We got you to think about it more and do it the right way. Glueing just the perimeter woulda been a mess in no time.
Jaz
Old 12-12-2015, 11:25 AM   #12
Rewards Points: 511
Jaz
It certainly wasn't from this forum. I found my answer on a Google search. Still have had no response regarding how to glue the vertical edges.
And have not heard one specific suggestion regarding how it should be done (differently) in my area of the US.
Stating that it should be done "the right way" doesn't help anyone who's never done it before.
Old 12-12-2015, 06:15 PM   #13
Rewards Points: 398
Use outdoor adhesive, not latex. Trowel the same adhesive on the vertical edges, let it tack up and it will hold the carpet. If you don't want to wait, after you spread the glue, put some hot melt glue from a glue gun on it and press in place immediately. The hot melt will hold it while the other sets up.
Use the right trowel, it will tell you on the bucket.
Old 12-13-2015, 01:54 PM   #14
Rewards Points: 511
Thank you.
Old 12-13-2015, 02:37 PM   #15
Rewards Points: 511
HD sold me Roberts 6700 Indoor/Outdoor adhesive which I see is latex. What is the non-latex adhesive made of. I see DAP makes one that is solvent based. No indication of latex listed on its' specs.
What will happen to the latex-based adhesive if I use it outdoors.
Help with Glue GRFagan General DIY Discussions 19 01-25-2012 08:03 AM
To Glue or Not To Glue denvermatt Carpentry 9 08-22-2011 10:21 PM
Glue on sheet rock barbarajones Painting 4 06-18-2011 11:35 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 11:12 PM
glue to a mirror Leprichon Interior Decorating 9 04-19-2009 03:16 AM
