Other Alternative Than Self Leveling Compund? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-30-2013, 05:49 AM   #1
Rewards Points: 1,184
Other alternative than self leveling compund?
I am installing laminate upstairs (subfloor is OSB)
In one of the room, I had to put some self leveling compound to compensate a pitch
Now, i am doing the hallway and i need to do the same thing to have the laminate even with the other room
The area is small (it's like a triangle, being in a corner) and max depth is 1/2"
I don't need the self leveling action of an SLC. I will use a straight edge to "spread" it even
Could I use something else, such as a thin set mortar or other?
french_guy is offline   Reply With Quote
Old 05-30-2013, 06:09 AM   #2
Retired Moderator
Rewards Points: 7,174
Laminate floating floor?
I have heard of people using layers of roofing shingled to flatten out floors for laminate---
Never tried that one---but I'd consider it ---
As to thinset?--it shrinks when laid down thick---I would not use it---
Old 06-02-2013, 06:07 AM   #3
Yes, I thought about the roofing felt....But I am concerned that several layers may be noisy together?
I was also thinking about wood filler, since the area is not that big?
Or even some subfloor glue that comes in the big cartridges (not sure if it becomes hard when it dries....)
Old 06-02-2013, 06:12 AM   #4
Retired Moderator
Wood filler is pricy ---Durhams Water putty is handy and should be in everyones shop--but is not good for this use.
Thinset would work---but it takes 12 to 24 hours to set--and shrinks and cracks when applied to thick.
Self leveling compound is the right stuff----sets fast---
Old 06-02-2013, 06:19 AM   #5
May I ask why it's not good for this use?
Old 06-02-2013, 06:25 AM   #6
Retired Moderator
Just the cost-----if the price doesn't bother you---go ahead.
Durhams sets up quick---shrinkage is minimal----
Old 06-02-2013, 06:37 AM   #7
It's in the corner of a hallway. I will have to go from 10mm from the highest point to 0mm on (2' width x 5' length - it's a triangle)
I was planning to put some 1/4" plywood I have left to minimize the Qty of putty.......
Old 06-02-2013, 07:48 AM   #8
Retired Moderator
As long as the floating floor has no hollow spot under it--the product is quite forgiving---do what it takes to get the subfloor flat and you should be okay.
At the risk of being flamed...tub leveling alternative. mgh-pa Kitchen & Bath Remodeling 16 01-08-2013 11:57 AM
Door issues leveling 1 degree slope in room Woodbury Carpentry 1 08-07-2012 06:24 AM
Looking for Dricore leveling alternative vluzhko Flooring 2 01-03-2012 05:10 PM
Drywall or studs first before self leveling cement sandoy1121 Flooring 0 07-26-2010 06:50 PM
Portland based self leveling underlayment under travertine floors Keith Carlson Ceramic Flooring 7 01-25-2009 03:58 PM
