Original Flooring Questions - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chandler48
Old 09-08-2017, 06:27 PM   #1
Rewards Points: 38
Original flooring Questions
Got around to pulling 1975 vintage dishwasher out of its hole and saw this. Vintage 1970s vinyl. The dishwasher and the sink next to it had leaked for a while many years ago. I had to cut the back leveling foot off as it had sunk into the rotten osb. Well my question is the vinyl seems to be glued to a hard plastic layer which in turn is glued to the osb. Eventually i will redo the flooring in the entire kitchen so not being a flooring expert what was that plastic layer and how best to patch that small area for now? House is on crawl space with 16" joists and 2x10 diagonal. There is newer vinyl over the vintage vinyl on the rest of the floor.
Original flooring Questions-20170905_160912-88-.jpg   Original flooring Questions-20170905_161217-86-.jpg   Original flooring Questions-20170908_174319-80-.jpg   Original flooring Questions-20170906_164315-90-.jpg
fuzzybear is offline   Reply With Quote
Old 09-08-2017, 06:33 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,294
Re: Original flooring Questions
Sadly that is not OSB, but particleboard, and should be removed before you contemplate re flooring the area. It swells pretty badly, as you know. The best way to do it is with a "kick" saw around the perimeter, chasing it with a multimaster in the inside corners. Once removed, you can assess what you have for subfooring and add the appropriate layers to accommodate the flooring you plan on using.
Dave Sal likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 09-08-2017, 06:44 PM   #3
Rewards Points: 38
Particleboard ugghh. Yes it has swelled and produced waves in the flooring. I was thinking of pulling the cabinets up and redoing ALL the flooring but they appear to be built on sight. And that would be a lot of work.
Old 09-08-2017, 06:51 PM   #4
retired framer
Rewards Points: 20,602
They were built as a unit not like boxes today. they may come out. Look for screws in the back and thru the kick in front. Sometimes there is a thin layer on the kick that went in last and the screws will be behind it.
Old 09-08-2017, 07:05 PM   #5
Rewards Points: 38
Thanks, will check that out.
Old 09-08-2017, 07:12 PM   #6
retired framer
Depending age, you may just find nails.
Hardwood Flooring Install Questions Lee Bob Flooring 9 11-15-2012 08:00 AM
Flooring, foamboard, finish floor question(s). edselsouth1 Flooring 7 04-26-2012 12:34 AM
Two questions for T&G flooring Mark Harvey Flooring 9 01-06-2011 08:27 AM
A few questions about bathroom flooring and repair dsnider420 Flooring 1 10-30-2008 09:21 PM
Flooring questions joemanuelking Flooring 2 12-01-2007 06:25 PM
