Old Pergo-glued Together-flooring Repair Ugh! - Flooring - DIY Chatroom Home Improvement Forum
Old 04-28-2015, 05:33 PM   #1
Rewards Points: 12
Old Pergo-glued together-flooring repair ugh!
So... I have a 1960's ranch in Florida that had a planter in the floor... Long story short...planter was removed and pergo flooring needs to be replaced.
This is an old pergo floor that has been glued together and is extremely difficult to get apart.
I cut out portions of the floor with a reciprocal saw (that's all I had)...as much as I could do without damaging the other boards. I marked (with a black marker) all boards and pieces that need to still be cut out. I am planning to go buy a circular saw and a particular dremel attachment to see if I can cut out the remaining pieces.
I have 10 full boards that I found in my garage.
Do you think this job is doable?
I'm procrastinating because I'm dreading taking on this project.
Anybody in Florida that wants a flooring job?? lol
(not sure how to rotate the photo)
dlisinski is offline   Reply With Quote
Old 04-28-2015, 07:39 PM   #2
Rewards Points: 18,382
Wasting your time, you need to replace the whole floor.
One of the dozen or so reasons any of use full timers suggest never using laminite flooring.
Tags
flooring , laminate , pergo , repair , replace
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
patching holes in vinyl flooring with formica repair kit h82diet Flooring 1 12-02-2011 11:18 PM
Pergo flooring acclimate ?? ants1929 Flooring 1 02-13-2011 05:13 PM
Engineered hardwood flooring - depression repair MShomeowner Flooring 7 02-06-2011 04:00 PM
split vinyl flooring repair tips caroleokeeffe Flooring 1 07-07-2008 08:17 PM
