Oak Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 06:54 PM   #1
oak flooring
where to acquire splines for making groove to groove connections in hardwood tongue and groove flooring?
PGRAY317 is offline   Reply With Quote
Old 03-04-2012, 06:57 PM   #2
Rewards Points: 18,376
Anyplace that sells flooring, or make your own.
Old 03-04-2012, 07:03 PM   #3
Too Short? Cut it Again!
Welcome and what a question to start!
Hadn't thought about the need in awhile but think a real lumber yard would still sell or be able to order you such.
Whether you can find what you need milled in matching hardwood? I have run across solutions in supposedly non-squeak extruded nylon/plastic and aluminum and assume if you nail it or glue it it will not fail any more than wood inserts or actual tongues into grooves?
How much do you need? Hopefully you do not have too many groove to groove joints to work out?
Flooring guys will have better suggestions.
Old 03-04-2012, 07:03 PM   #4
the Musigician
DangerMouse's Avatar
I use my table saw and scraps.... much cheaper.
DM
Old 03-04-2012, 07:17 PM   #5
DM
Thanks danger rodent.
Table saw could work. I sometimes forget the obvious is right in front of me. You should be able to rip pieces from scrap flooring. Rubber mallet and maybe polyurethane glue like Gorilla Glue? Good to go! Tongues where none were moments before.
How much of a t&g mismatch do you have though? Sure all nailed in opposing directions is in place? Patching grooves with inserts of whatever kind is what it is. It is never the same as milled wood from the same piece.
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 07:24 PM
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 03:00 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-30-2011 12:06 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
