New Tile Subfloor ADVICE NEEDED - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joecaption
Old 04-29-2018, 04:06 PM   #1
Rewards Points: 4
Question
new tile subfloor ADVICE NEEDED
Hello friends,
Existing kitchen floor is 3/4" pine boards (7 1/2 wide, 1/4-1/2" gaps) with 5/8" MDF and Linoleum. It needs to meet the adjacent room oak flooring which sits 3/4" off the pine boards.
So the new tile floor has to total 3/4". If I use 5mm tile (1/4") should I keep the pine boards and add 1/4" plywood + 1/4" backer board? Something different? What should I do?
Thanks! TIM
flatlanderia is offline   Reply With Quote
Old 04-29-2018, 04:39 PM   #2
Rewards Points: 986
Re: new tile subfloor ADVICE NEEDED
Unfortunately, I do not believe your "pine boards" are an acceptable subfloor for tile. You're going to want 3/4" plywood/OSB. Then you use the backer of your choice (1/4 or 1/2) to flush with your hardwood.
Marson is offline   Reply With Quote
Old 04-29-2018, 06:39 PM   #3
Rewards Points: 17,914
MDF as an underlayment for tile, not going to happen?
Sure it's not particle board which would also be unexcepticle as as an underlayment for tile.
Tile is a one shot deal, not what they show on the DIY shows.
What size are your floor joist, what's the free spans?
The last thing I worry about when laying tile is the height difference.
Transition strips can deal with that.
Old 04-29-2018, 07:36 PM   #4
Rewards Points: 4
Floor joists are 2x8, 16 on center.
Old 04-30-2018, 08:02 AM   #5
What's the unsupported span?
HDS likes this.
Old 05-02-2018, 07:00 PM   #6
Rewards Points: 4
unsupported span is 11' from a steel I beam to the outside foundation wall.
Second opinions needed: laying new tile B&N Tiling, ceramics, marble 30 04-30-2015 05:36 PM
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Bathroom tile advice needed. John_W Flooring 13 02-08-2013 01:57 PM
Pool Patio Tile Help Needed cpelliott Tiling, ceramics, marble 4 04-10-2012 05:33 PM
Help on materials needed for granite tile c4m4r0 Flooring 4 06-02-2007 02:05 PM
