New Laminate Flooring Question (regarding Termination At Sliding Door) - Flooring - DIY Chatroom Home Improvement Forum
Old 12-26-2018, 07:05 PM   #1
Rewards Points: 744
New laminate flooring question (regarding termination at sliding door)
Hi there.
Iím thinking about putting a floating laminate wood floor in my sun room (turned kids play room) and was wondering how to best terminate the flooring at the sliding door. Right now the top of the door track sits flush with the tile floor. If I simply put the floating floor on top of the tile then it wonít sit flush. Does it matter? Is there a better way to deal with this transition that doesnít involve ripping out the existing floor?
Thank you...
New laminate flooring question (regarding termination at sliding door)-4449c384-86db-47bc-9a92-76046d7988b9.jpg   New laminate flooring question (regarding termination at sliding door)-ebf076c0-81b4-472c-829d-a68f4e617790.jpeg
harpua728 is offline   Reply With Quote
Old 12-26-2018, 07:14 PM   #2
retired framer
Rewards Points: 334
Re: New laminate flooring question (regarding termination at sliding door)
Just put a transition there.
Old 12-26-2018, 07:18 PM   #3
Rewards Points: 744
The transition would make my problem worse. In your picture, the wood floor sits below the door tracks and the transition helps build up the floor. In my situation, the new floor would sit higher than the tracks and this type of transition board will only make it worse. Or so I think.
Old 12-26-2018, 07:28 PM   #4
Rewards Points: 744
I guess this type of threshold will work in that it would cover the exposed end of the new flooring. The door tracks would still sit below the level of the new floor but I guess Iíll just have to live with that.
New laminate flooring question (regarding termination at sliding door)-a7856322-0e1b-42e5-a8a2-92c07392a29c.jpeg
Old 12-26-2018, 07:31 PM   #5
retired framer
Rewards Points: 334
We set windows like that on a 2x4 to help people like you but then everyone has to step over something. As every exterior door has a threshold most people are used to that and step over it.
Closet Door and Laminate Flooring issue. greentrees Flooring 9 10-28-2014 10:13 PM
Joplin Tornado Question - Laminate Flooring Rasmus Flooring 1 06-21-2011 10:40 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
Question about mills on laminate flooring cpsilo1 Flooring 3 07-25-2005 01:05 PM
