New Daylight Basement Slab - Sealer? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-22-2013, 01:27 PM   #1
we just finished pouring our new daylight basement slab (was an old carport).... long story.
any how, my question is do I need to seal the slab? we're just going with the concrete as the finished look. Maybe laminate in the future. There is a new vapor barrier under the slab and proper French drains have been installed.
if so, what is a good sealer to use. I don't want anything too glossy.
Thanks!
Glenny is offline   Reply With Quote
Insulating Daylight Basement Questions Tweak3D Insulation 8 10-06-2012 12:36 PM
crawlspace slab voids, basement water geoffmiller Building & Construction 0 11-25-2011 09:01 AM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Porcelain Install Job on Basement Slab, How to make Floor Drain Flush... Firehawk734 Flooring 13 11-17-2011 09:30 PM
Water under slab in basement CharlieV. Plumbing 3 10-12-2011 02:25 PM
