New Bathroom Tile Floor. - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By huesmann
Old 06-29-2020, 04:25 AM   #1
Rewards Points: 14
New here.
In the process of a bathroom remodel and interested in the correct way to deal with this toilet flange?
I will be installing 1/4 backer board followed by a tile floor.
Any advice is appreciated and sorry if this is posted in the wrong area.
Thanks,
Bob O is online now   Reply With Quote
Old 06-29-2020, 04:36 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,532
Re: New Bathroom Tile Floor.
You need to replace it, but it shouldn't be a difficult task since you may have to replace subflooring as well. It looks to be i pretty bad shape, too.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-29-2020, 04:41 AM   #3
Rewards Points: 14
Thanks Larry.
Do these flanges break/separate fairly easily from the pipe or should heat be used?
Old 06-29-2020, 05:21 AM   #4
Naildriver
chandler48's Avatar
It is difficult to tell what it is made of...cast iron, PVC. What type pipe is below it?
Larry......
Old 06-29-2020, 05:27 AM   #5
Rewards Points: 14
All cast iron. I think the house was built in the 70's
Old 06-29-2020, 08:43 AM   #6
Rewards Points: 4,382
But if you're like me, and you don't want to deal with lead and oakum, you're gonna get a diamond cutting wheel for your angle grinder and cut off the flange, so you can install one of these:
They come in 3" and 4" dia, depending what the dia of your cast iron pipe is.
huesmann is offline   Reply With Quote
Old 06-29-2020, 09:56 AM   #7
dj3
Rewards Points: 1,316
You need to do something with the subflooring too as mentioned, it looks dry rotted.
dj3 is offline   Reply With Quote
Old 06-30-2020, 12:44 AM   #8
Rewards Points: 14
Thanks All!
I'll pick up a cutting disk and address the sub floor.
Old 06-30-2020, 05:12 AM   #9
retired framer
Rewards Points: 15,284
huesmann likes this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-30-2020, 05:28 AM   #10
Rewards Points: 42
Hey it's totally dry and rotted, you should look into replacing the whole picture including your subflooring
justinrobinson is offline   Reply With Quote
Old 06-30-2020, 08:58 AM   #11
Originally Posted by Nealtw View Post
Pretty sure I watched that video when researching my own issue.
I couldn't find the type of flange they used, though, so I just went with the twist-n-set version.
Nealtw likes this.
Old 06-30-2020, 05:23 PM   #12
Rewards Points: 14
How forgiving are the 3 screw/bolt flange inserts sealing wise? I will probably do more clean-up with my die grinder once I know where the seal will sit.
Old 07-01-2020, 09:57 AM   #13
I would clean up as much scale as I could where the seal is gonna seat. I used an abrasive wheel like this:
Old 07-02-2020, 01:51 AM   #14
Rewards Points: 14
Thanks. I haven't used one of those in years and had forgotten all about them.
