Need Some Help With Pee Stained Plywood. - Flooring - DIY Chatroom Home Improvement Forum
Old 08-12-2014, 06:04 PM   #1
Rewards Points: 30
Need some help with pee stained plywood.
Hey friends, I am working on getting this one room in my new house fixed up. When I went through my initial walk through the home had no foul smells at all. When I take ownership the first thing I notice is one bedroom STINKS of cat pee. I ripped the carpet up in that room and I'm planning on replacing the plywood floor in the bad areas, my only issue is I have one area that saturated that I won't be able to cut out completely. It's in a closet with makes this more challenging. There is NO SUBFLOOR to remove here, only 3/4" ply ontop of joists. My plan is to just cut that area out as far as I can go and spray paint it with kilz oil based paint, and really saturate it. Not just from the top, but the side as well. I have had experience doing this sort of thing when I worked in the construction trade and never had a call back, but always wondered if it actually contained the smell for good, and is there anything else I can do to further contain the smell, and make sure that this will be the end of my issue. Thanks in advance for advice.
-Vinnie
VinnieVega is offline   Reply With Quote
Old 08-12-2014, 07:00 PM   #2
I have heard of a enzymatic solution that you can use to kill the odor. Other than that I have heard of people using a shellac primer zinnsler to cover it . Bust I have never had this issue personally.
Sent from my SM-S765C using diychatroom.com mobile app
nismo972 is offline   Reply With Quote
Old 08-12-2014, 07:07 PM   #3
Rewards Points: 30
I need the name of a good enzymatic solution in that case.
Old 08-12-2014, 07:34 PM   #4
Jmayspaint's Avatar
Rewards Points: 538
Shellac will seal it better than oil.
Jmayspaint is offline   Reply With Quote
Old 08-12-2014, 08:19 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 780
Vinnie,
The 3/4" ply is THE subfloor, anything above it is an underlayment.
According to Mr. Zinsser the best pet urine sealer is their; B-I-NŽ Advanced Synthetic Shellac Sealer Clear.
Get this one specifically, they have several others that mention shellac and sound similar. The others claim to block pet odors, this one claims "pet urine".
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 08-12-2014, 08:32 PM   #6
Rewards Points: 30
Thanks! That seems like the one.
What should I clean it with before hand?
Old 08-12-2014, 09:28 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 780
Clean what with, the plywood? Is it dirty? If so, mop with cleaner then rinse well. Use two separate mops and pull rinse strokes towards you, not back and forth.
Jaz
Old 08-12-2014, 10:35 PM   #8
The cleaner is natures miracle found in pet supply section. Claims too be a urine destroyer. :-)
Old 08-13-2014, 02:10 AM   #9
Rewards Points: 201
I wish I could remember the name of the product, but when I had a similar problem I had some success with a white primer sold for sealing in smoke odors during post-fire rehab.
Run and find ou is offline   Reply With Quote
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
It is hard to find 1/2 t and G plywood so would regular plywood be ok ? dewi Flooring 14 05-04-2010 12:05 PM
Tile over plywood? Thurman Flooring 3 07-12-2009 09:05 AM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 12:11 PM
