Need To Raise Carport Slab 10" To Match House Slab For Room Addition - Flooring - DIY Chatroom Home Improvement Forum
Old 04-15-2015, 01:15 PM   #1
Rewards Points: 2
Need to raise carport slab 10" to match house slab for room addition
We have a 20'x 24' carport that sits adjacent to two exterior walls of our house. We want to close in the carport area as a room addition to house, however carport is 10" lower than house slab height. Carport is at grade with surrounding soil. Want to know if I could do any of the following instead of spending $$ to pour concrete to level up the 10" difference.
1) Pour a small knee wall ( 4" wide by 10" tall) of concrete on top of existing slab perimeter and use 8x8x16 double hollow concrete blocks bumped one against another in the entire area area with holes turned sideways, so forms nearly solid concrete top. Top off with one layer of 3/4" treated T&G plywood ( structural glue to blocks) and then a second layer of 3/4 non-treated T&G plywood turned 90 degrees from the first layer, so seams are staggered. Screw top layer to second layer, with glue in between. My finished height will be about 9.5 inches which is almost the same as the needed 10". ( This process is less than half the cost of pouring a 10" slab to level up height difference.
2) Alternate idea: Simply build a 2x10 "sleeper floor" structure ( 12" oc) and top with plywood. Will provide just about 10" height. The 2x10's would be pressure treated, since they will be against the slab surface. Concerns: Termites since 2x10's are at grade and risk of eventual water damage if water seeps in between existing slab and the 2x10? However, treated should last in this condition for decades? This process is something I can do "alone", unlike pouring a slab. This idea is about 2/3 the cost of pouring 10" of concrete.
Do I need to worry about venting if I choose either method. I would put vapor barrier over existing concrete.
Would either of these ideas work well?
Thanks,
Manfred
manfredswinkle is offline   Reply With Quote
Old 04-15-2015, 01:21 PM   #2
PoleCat's Avatar
Rewards Points: 1,652
Odds are that your carport slab is floating. This makes it unsuitable to build on. You need a proper foundation set at the correct depth for your area.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following 2 Users Say Thank You to PoleCat For This Useful Post:
JazMan (04-15-2015), mae-ling (04-18-2015)
Old 04-15-2015, 02:18 PM   #3
Rewards Points: 18,384
None of those ideas sound good.
Post a picture of the area when you get enough post.
Most common way is to build it up at the edge of the slab with concrete block making what's called a stem wall. Google it.
JazMan (04-15-2015)
Old 04-18-2015, 09:06 AM   #4
Rewards Points: 30
The only correct way to do this is to build a foundation around the entire area to be closed off. This should be what ever code is in your area. Once the area is closed off you can put #57 stone right on top of the existing slab and fill the entire area up with rocks, just leaving enough room for a 4" slab. The last time I purchased this stone (which was a few years ago) it was around $18.00 a yard, vs. $120.00 a yard for concrete. I suggest you consult with your local government, and get a permit for this project before going any further.
VinnieVega is offline   Reply With Quote
Old 04-18-2015, 09:27 AM   #5
Rewards Points: 2,264
If it is indeed a 'floating' slab. You will need to cut away around the perimeter. Pour a proper footing. Eihter a wall or piles depending on your area. Some would leave the old concrete slad inside the new footing if it is in good shape to act as a concrete floor.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
Canarywood1 (04-18-2015)
Slab under slab in 100yr old house Master Brian Building & Construction 2 08-23-2010 08:35 AM
3 year old house, new crack right through slab aaronb9 Remodeling 5 10-09-2009 04:49 PM
conc slab inside/under a enclosed metal carport blthomas Building & Construction 3 02-01-2008 10:18 AM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
