Need Help Figuring Out A Pattern - Flooring - DIY Chatroom Home Improvement Forum
Old 09-23-2015, 10:54 AM   #1
Rewards Points: 165
Need help figuring out a pattern
I would like to replicate this in my foyer. What is the best installation method? I am also not sure about what accents or borders are around the tile. Has anybody seen anything like this?
vettegc is offline   Reply With Quote
Old 09-23-2015, 07:23 PM   #2
Rewards Points: 16
What is the material thickness? 3/8" is it glue down instalation? do you have the router equipment to tounge and groove the custom fabricated pieces?
Im not a wood guy but, the border has 32 identical field triangles (red) with 4 pairs of the inside corner (blue) and 4 pairs of the out side corner (black). I personally would prefab these parts first. Precut the mitered border stripes. lay out the floor to center the assembly. install the border, install the inset, install the outside wood to the walls and as a final install the traverteen and add finish.
charimon is offline   Reply With Quote
Old 09-23-2015, 08:01 PM   #3
Property Mgt/Maint
Rewards Points: 7,582
The complexity here would require a complete layout underneath prior to starting.
This looks nice. Elaborate, however I have my doubts as to durability. With wood expanding and contracting, and different mat'ls expanding and contracting at different rates. The real possibility of complete disaster is high. But who doesn't love a good challenge.
Good Luck and keep us in the loop if you decide to try it
[political signature removed]
Yodaman is online now   Reply With Quote
rim joist pattern hidden1 Building & Construction 5 10-21-2014 08:58 AM
How's my HVLP spray pattern look? And how can it be improved? RickDel Painting 5 10-04-2014 01:32 AM
whole/half pattern composite shingles new homeowner Roofing/Siding 2 09-09-2009 10:15 PM
Gilmour Pattern Master Sprinkler rohnds Landscaping & Lawn Care 4 05-21-2007 01:22 PM
Shingle Pattern gilberte Roofing/Siding 7 09-05-2005 04:37 PM
