Need Advice In Regards To Carpet Replacement - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Mikeron
  • 1 Post By stick\shift
Old 01-01-2017, 08:52 AM   #1
Rewards Points: 2
Need advice in regards to carpet replacement
Hey guys-new member here. My living room is carpet. I have a senior cat that's pee'd on it for years. Recently tried to clean it up but it's too far gone. I want to replace it with something non absorbing.
Not a real stylish person. Function over form.It's a 13'x13'6" square if that matters.
Thanks in advance
Travis
TurboTravis is offline   Reply With Quote
Old 01-01-2017, 09:02 AM   #2
Rewards Points: 294
Re: Need advice in regards to carpet replacement
I would replace it with linoleum.
Sent from my XT1031 using Tapatalk
joecaption likes this.
Mikeron is offline   Reply With Quote
Old 01-01-2017, 09:14 AM   #3
Rewards Points: 4,170
I would do nothing other than attempt to keep the carpet clean until the cat is no longer around.
Dave Sal likes this.
stick\shift is offline   Reply With Quote
Old 01-01-2017, 04:49 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 2,168
Once urine is gotten into the backing and underpad, and possibly the subfloor, it is really difficult to remove. A profession carpet cleaning service that has good recommendations for pet stains might be able to get it out, and least to the point that it is not noticeable. Consumer-grade machines probably won't cut it. It's a relatively inexpensive option that might buy you a few years.
lenaitch is offline   Reply With Quote
Carpet in the basement Packer Backer Flooring 17 11-30-2018 02:10 AM
Advice on Slate Roof and total roof replacement mdandy8 Roofing/Siding 13 05-24-2012 08:29 AM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 08:35 AM
Need advice on installing indoor/outdoor carpet Krichton Flooring 1 06-27-2007 03:36 PM
