Nailing Pattern For Luan Underlay? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-25-2015, 09:48 AM   #1
Rewards Points: 294
Nailing pattern for luan underlay?
I have some stick down tiles to lay on 1/4 inch luan, how far apart should I hammer the nails in, I was told 6 inch apart.
Mikeron is offline   Reply With Quote
Old 04-25-2015, 09:59 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 394
Luan is not an accepted underlayment.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-25-2015, 10:17 AM   #3
Rewards Points: 294
Why not and what would be a better choice?
Old 04-25-2015, 10:20 AM   #4
Rewards Points: 294
I got my info from this video
https://youtu.be/cefcEKvZuJY
Old 04-25-2015, 01:18 PM   #5
Rewards Points: 18,370
It causes glues to reliece, it has voids, the color can bleed through the flooring.
Should be using 1/4 multiply subfloor rated plywood.
Use nails and your going to have to go back and fill everyone of the dimples, use a pneumatic narrow crown staple gun and it's far faster and no need to fill the tiny holes.
It's 4" on the edges and 6 to 8 in the field.
Make sure the seams do not line up with the seams below, NO GLUE needed.
Hope your not using peel and stick tiles!
Old 04-25-2015, 01:34 PM   #6
Rewards Points: 294
Yes they are peel and stick with a primer rolled before the tiles
Old 04-25-2015, 01:53 PM   #7
Peel and stick is near impossible to lay in a straight line because it tries to stick to fast and there's no adjustment.
They tend to shrink and gaps open up.
Some just will not stay stuck down.
Should be attached directly to the plywood not over a primer, may not stay stuck down with a primer.
Old 04-25-2015, 06:19 PM   #8
Rewards Points: 394
Everything in that video is wrong. No surprise. Almost everything on Youtube about flooring is wrong.
The Following User Says Thank You to rusty baker For This Useful Post:
JazMan (04-26-2015)
Old 04-26-2015, 03:38 AM   #9
Rewards Points: 978
love rusty's posts and info here
federer is offline   Reply With Quote
Old 04-26-2015, 01:42 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 780
Mikeron,
I watched the video last night and if you're referring to the one by Mr. Clement, I agree he should be doing something else. But another video started right after. The 2nd video looks good to me, it's by SurePly. Is this the one by chance? Forget the first one.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Laminate floor and underlay sleong Flooring 1 10-01-2012 09:48 PM
lvl nailing pattern J Starcevich Building & Construction 2 08-27-2012 10:50 AM
Looking for an underlay - does this even exist? sarsnake Flooring 6 10-18-2011 05:22 PM
Drip Edge/Gutter Apron Nailing Pattern? echase Roofing/Siding 1 03-17-2010 12:09 AM
Crown moulding nailing and blocking pattern Klawman Carpentry 2 01-13-2010 12:22 PM
