Multi-Purpose Sub Floor - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-23-2015, 06:11 PM   #16
Tileguy
JazMan's Avatar
Rewards Points: 780
I meant the plywood seems cheaper than Ditra.
I still don't get it. Why compare plywood with Ditra?
I saw that membrane at Menards, I kinda giggled at it.
Ditra over heat is good too. You're supposed to pour SLC over the heat mat to embed it and make the floor flat, then install Ditra. Or, have you checked out Ditra-Heat? Fantastic. http://www.schluter.com/ditra-heat.aspx
I can purchase Ditra online and have it shipped to me.
Yup, I hear Nebraska is a fairly civilized place and there's deliveries made most every day.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 08-23-2015, 11:18 PM   #17
Young Bachelor
CTSNicholas's Avatar
Rewards Points: 479
Funny! Yeah the Ditra Heat looks nice, but it is also a lot pricier. :P
So if I use 3/8" Plywood for vinyl...I can come back and install tile over it - or Ditra over it to be extra sure and still have a thin profile.
If I want to have heated tile using a product like this: http://www.homedepot.com/p/SunTouch-...630R/100027475 it looks like I just have to prepare for the additional step of a self leveling underlaying cement before the tile thin set.
CTSNicholas is offline   Reply With Quote
Old 08-24-2015, 10:54 AM   #18
Tileguy
JazMan's Avatar
Rewards Points: 780
No, I didn't say you should install tile direct over the plywood.
You need to study all the directions of the warming system you wanna use. If you go with SLC you'll need to install metal lath and the SLC will end up being ⅜- ½" thick, If they recommend thinset mortar, you'll have to go back and float the areas where there is no warming mat. Is Ditra Heat sounding better now?
Jaz
Old 08-29-2015, 10:52 AM   #19
Young Bachelor
Rewards Points: 479
I think the best option I have is to install 1/4" Ply Substrate and install vinyl in the three locations I want tile later. When that day comes, could I then install 3/8 Ply atop the 1/4" substrate or should I just tear up the 1/4" and use a new single layer solid tile substrate before tile mortar?
Floor direction for new hardwood over 1925 hardwood on sleepers? jsimma Flooring 2 07-21-2015 05:47 PM
Power problems on second floor, first floor is fine rarken1 Electrical 21 05-16-2015 12:42 PM
Termite wood floor as sub-floor gtimk4 Flooring 1 09-21-2011 07:30 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
