Multi-level Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 06-27-2018, 11:27 AM   #1
Rewards Points: 2
multi-level flooring
My kitchen (laminate) flooring is a different height than my hallway (carpet going to laminate) by 2”. There used to be a shim for a ramp to make up the height difference which was fine for carpet. I am wanting to replace the carpet with laminate and i don’t think it would work without tearing the laminate. I would like to keep it as a small step but need a way to stop my kitchen floor from tearing up from being stepped on. I am also ok with a ramp system but not sure how to go about either. Any help is appreciated.
jpalmer2013 is offline   Reply With Quote
Is this level 5? mla12 Drywall & Plaster 10 01-15-2017 09:54 AM
Laser level, sight level, or other level methods with high accuracy? viper Building & Construction 13 06-24-2016 10:35 AM
install engineered wood flooring in entry way of split level Novice2 Flooring 1 01-13-2012 06:45 PM
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 02:00 PM
the multi level sorta pony wall shlleys Carpentry 1 08-27-2011 12:48 PM
