Maple Sill Which Seperates Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 04-03-2012, 10:02 AM   #1
Maple sill which seperates flooring
I have a maple (sill), not sure about the correct name which separates a living room carpet from a tile kitchen floor. The sill came loose from the concrete underneath, what kind of adhesive can I use to permanently attach to the floor?
Attached you see a pic of the sill and whats underneath it.
Maple sill which seperates flooring-forumrunner_20120403_100142.jpg   Maple sill which seperates flooring-forumrunner_20120403_100149.jpg
Keith vent is offline   Reply With Quote
Old 04-03-2012, 11:19 AM   #2
Ravenworks's Avatar
That is called a "Transition strip"
You can use construction adhesive to anchor it back
Ravenworks is offline   Reply With Quote
Old 04-03-2012, 11:37 AM   #3
Smile
Transition strip
Thanks sir, I will try applying construction adhesive to the strip and see if that works.
Old 04-04-2012, 01:52 PM   #4
Liquid Nails
That is the best one I have found that works well with wood....
Hope that helps..
Clayton
hardwoods4less is offline   Reply With Quote
refinishing reclaimed maple flooring mnp13 Flooring 27 11-19-2014 11:25 AM
Maple vs. White Birch Engineerd wood flooring JMK601 Flooring 9 04-01-2012 03:40 PM
Darkening Maple Flooring albany Flooring 0 03-21-2012 11:01 AM
Old maple flooring for countertop? This Old Spouse Kitchen & Bath Remodeling 9 02-28-2011 02:17 PM
Solid Maple Flooring over OSB Ron6519 Remodeling 10 08-27-2009 12:52 AM
