Making A Half Moon Arch At Door Entry - Flooring - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 07:09 PM   #1
making a half moon arch at door entry
How do i work with the laminate snap together flooring to create an arch?
d.stark is offline   Reply With Quote
Old 05-29-2013, 07:15 PM   #2
Rewards Points: 17,912
Are you talking about an arch at the top of a door way?
I have to ask because there's just no way to do it.
It's not made to bend and will just snap in half.
It also has to have room to expand and contract, can not be face nailed.
Old 05-29-2013, 08:10 PM   #3
Rewards Points: 6,652
Find center of the door, take a string that is as long as you want the entry to be deep, then lay down a piece of cardboard larger than the opening, and deeper than how far you are going to lay the floor.
Use a pencil at the end of the string, and draw the arch. When done, you have a template to lay on top of the flooring, to be able to cut the pieces for the arch.
Keep in mind that the arch will only be as deep as the doorway is wide, unless you plan on going just past where the trim pieces are, then it will be as long as that area is wide.
Old 05-30-2013, 02:03 AM   #4
It will be better if you add a pic of your door, to make clear on your doubt.
henrylarry6 is offline   Reply With Quote
Old 05-30-2013, 07:44 AM   #5
Not needed, due to the way I described works for anytime you need to form a arch. Not that hard to do, if you follow directions and take time to do it right.
making starters from Arch. Shingles diyroofer Roofing/Siding 13 09-19-2011 08:52 AM
half moon wood step plans germaine Carpentry 2 07-13-2011 12:10 PM
Flashing around a half moon window cocean Carpentry 0 08-30-2009 08:50 AM
Making a load bearing wall a half wall vjbozard Building & Construction 9 04-12-2009 03:11 PM
Half moon fixture n0c7 Electrical 7 08-28-2008 12:02 AM
