LVP Under Appliances And Cabinets In Kitchen - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By diycabinets
Old 12-30-2018, 10:28 AM   #1
Rewards Points: 160
LVP under appliances and cabinets in kitchen
I have used LVP several times now but never in a kitchen. I have a house I would like to use LVP throughout. It would be much easier to put the floor down in the kitchen before the cabinets, dishwasher, range and refrigerator. Would I experience any problems if I do this?
comfun1 is offline   Reply With Quote
Old 12-30-2018, 11:27 AM   #2
Rewards Points: 17,912
Re: LVP under appliances and cabinets in kitchen
That's the way I would do it.
A whole lot less cutting, faster, less likely to have subfloor damage if there's ever a leak.
If someone wants to remove it for some reason latter on it's simple enough to cut around it.
Old 01-24-2019, 07:07 AM   #3
Rewards Points: 58
If the floor floats it should not be "trapped" under cabinets.
This could result in buckling or gaps as the floor expands and contracts.
diycabinets is offline   Reply With Quote
Old 01-24-2019, 07:17 AM   #4
retired framer
Rewards Points: 20,238
I would install the cupboards spaced up, so the flooring can go under the edge a little and still move.
Domo likes this.
Old 01-29-2019, 06:04 AM   #5
Rewards Points: 58
Good luck with that. Installing the floor under floating cabinets will pose some additional challenges.
If you cut the floor within a 1/8 to a 1/4 inch of the cabinets before you install the toe kick material then the gap will be concealed by the toe kick.
When I installed my floor I made a boo boo and had more than a 1/4" gap on one end. I simply added another piece of 1/4" material behind the toe kick so it covered the gap.
Old 01-29-2019, 06:12 AM   #6
retired framer
The kick isn't the problem, its sides where the stove and fridge go.
Old 01-29-2019, 07:56 AM   #7
Rewards Points: 58
install the LVP under the range and stove all the way to the wall. The stove and fridge are, in essence, "floating" and will not cause the flooring any undue stress. I placed my LVP under those appliances. It also makes it much easier to pull those appliances out for cleaning, etc.
Old 02-10-2019, 09:04 AM   #8
Rewards Points: 2
I'm going to tap into this discussion - what about where a dishwasher would go? We are installing lvp in our kitchen and we're also updating cabinets so we can add a dishwasher (finally). Should we install the cabinets, then floor, then dishwasher?
sunfrogger88 is offline   Reply With Quote
Old 02-11-2019, 05:58 AM   #9
Rewards Points: 58
Yes. I would do it in that order. I did not put LVP under my dishwasher because it would have made the dishwasher opening too short but I did install the LVP right up to and slightly under the front of dishwasher.
moosehaed likes this.
Best paint for kitchen cabinets? W1ldC4ts14 Painting 10 10-13-2014 01:53 PM
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
Refacing kitchen cabinets without any veneer? loft_lover Carpentry 1 11-18-2010 06:23 AM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 10:23 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
