Luxury Vinyl Tile (LVT) Surface Prep? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-04-2014, 03:07 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 224
Luxury vinyl tile (LVT) surface prep?
I an considering LVT for the floor in my kitchen renovation. I am having the floor professionally installed but am doing the surface prep myself. My sub floor is 1/2" plywood on 2x10 joists 16 O.C. with a 12' span. I am planning on laying 1/2' BC plywood (glued & screwed) as the under-lalyment for the tile.
Does that sound like a reasonable plan?
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 05-04-2014, 03:13 PM   #2
Rewards Points: 18,376
Nope, underlayment does not get glued down.
Using narrow crown staples in a pneumatic staple gun is the fastest and does not leave any holes or flaws that need filling, just need to fill the seams.
Second choice would be underlayment nails.
Screws are going to leave humps that would need to be sanded down.
Do not have the seams line up with the seams below.
rjniles (05-04-2014)
Old 05-04-2014, 07:31 PM   #3
Retired Moderator
Rewards Points: 7,174
Rusty Baker know more than I do--so listen to him if he says my advice is bad---
As Joe mentioned--screws are over kill and might cause dimpling---
Small crown staples is the better choice---
I like to roll on a thin coat of Henry's Bond Enhancer--it's a clear latex primer that seals the surface and helps the sticky adhesive grab.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
rjniles (05-04-2014), rusty baker (05-04-2014)
Old 05-04-2014, 09:47 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
I agree with Joe and O'Mike.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
oh'mike (05-05-2014)
Mannington Adura Vinyl Tile digitaljimmy Flooring 2 02-03-2013 03:19 PM
Anyone install Menard's Designer's Image Luxury Vinyl Tile? Studly Flooring 4 11-18-2012 08:53 PM
Tiling over vinyl asbestos tile bhein57 Flooring 6 10-26-2011 01:36 AM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 01:08 PM
