Loose Wood Floor On Slab, Need Advice - Flooring - DIY Chatroom Home Improvement Forum
Old 08-17-2015, 12:37 PM   #1
We have a wood floor on a slab, there are 3 loose boards near a doorway and transition piece is off. How should I go about repairing the area? I assume I can just re-glue everything, but would rather do the job once properly. Also what kind of glue would I be looking for?
Thanks!
bracohen is offline   Reply With Quote
Old 08-17-2015, 03:53 PM   #2
Rewards Points: 744
urethane adhesive
Seattle2k is offline   Reply With Quote
Old 08-17-2015, 06:10 PM   #3
Rewards Points: 6
For the glue to bind the wood boards, use Titebond III waterproof wood glue or Dritac floor repair adhesive.
For repairing your floor, you have 2 options, either use glue to bind the wooden boards or just use nails for same. You may even use Liquid nails adhesive if it's a subfloors. Just make sure the last wood board should be glued and nailed to give a perfect finish.
Irma R. Lopez is offline   Reply With Quote
Old 08-17-2015, 08:07 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 750
Irma,
You may have missed the part about this is wood over a slab. I hope it's engineered wood, at least. The OP is not gonna be nailing anything.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Need some wood stove advice tls1 Remodeling 6 01-26-2015 09:23 PM
Insulate over slab / under wood floor mjoe Insulation 3 05-03-2011 08:53 PM
Faux Wood Tile Over Concrete Slab Oswald Flooring 4 08-05-2009 03:42 PM
Advice needed for filling wood cracks dave95sps Painting 2 10-01-2007 08:14 PM
Need some advice on how to remove ceramic tiles over wood floors. sandman512 Flooring 4 09-02-2007 11:03 AM
