Linoleum/Vinyl Sheet Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-11-2016, 10:27 AM   #1
I plan on replacing the dated floor in my bathroom. It was installed before I purchased the house, I believe it is vinyl flooring, but it could be linoleum. The house was built in 1840, and I do not know what year the floor was installed. Due to having two children and dogs in the house, I worry that the existing floor contains asbestos.
Is this something I could remove myself while taking the correct precautions (everyone out of the house, contain the area, respirator, etc) or could I tile over top of the existing floor?
Thank you in advance.
JRCustomWW is offline   Reply With Quote
Old 01-11-2016, 01:18 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 738
Only way to know if it has asbestos is to have it tested. Much of the older linoleum was loose laid. On those that were glued, The adhesive had much more asbestos that the linoleum. Can you post a picture? If it is vinyl, there is no asbestos in it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 01-11-2016, 01:36 PM   #3
Rewards Points: 2,906
While you CAN also tile over the existing floor as long as it's stuck down well and not lifting anywhere, it's not really recommended that you do that. The reason why is that the life of your new tile floor will be limited to the remaining life in your existing floor's glue. Once that old glue starts to let go, that's the end of your new tiling.
Mapei is probably the biggest name in flooring cements in the world and last I checked, Homeless Depot was selling Mapei products. Mapei makes a cement based floor leveling compound called "Planipatch" which is sold by the bag. They also make an "additive" (pronounced "adhesive") called "Planipatch Plus", which is really nothing more than a latex glue. On existing linoleum, you mix the Planipatch powder with the Planipatch Plus additive only so that the slurry you mix up sticks like he11. You then scrape off any high spots with a sharp paint scraper, vaccuum up, and apply a second coat. This time, dilute the Planipatch Plus with 3 parts water and use that solution to mix up your slurry, and spread that over the first coat. You then scrape or sand down any high spots in that second coat and vaccuum up. Finally, if a third coat is needed to get the floor smooth, you mix up that third coat using Planipatch mixed with water only. The resulting coat will be soft enough to sand smooth easily. Always use a bright light laying on the floor to help you identify high spots and any low spots that need to be filled with more floor patch. The above is called "floating" the floor to prepare it for a new flooring material.
And, if it wuz me, I would caulk between the new flooring and your toilet floor flange to ensure that if you ever have a leaking wax ring, the water shows up on top of your floor well before it shows up on any ceiling below. That will give you time to replace the leaking wax ring before you have to replace water damaged drywall or plaster.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-11-2016, 06:11 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 802
Let's see a picture of the flooring and give us a detailed description of all the layers below it.
What type of tile do you wanna install? "Tile" to us means ceramic which is what I recommend. Also give us details about the joists.
Asbestos in older sheet vinyl would be in the backing, not the surface and is why we ask for pics.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
Asbestos Vinyl Sheet Flooring Backing Codyy Safety 3 01-04-2012 11:09 PM
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 02:00 PM
First Timer - Questions About Hardwood Flooring for Stairs sunshine54 Flooring 0 10-16-2011 10:44 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
