Linoleum, Laminate Or What--Bourbon Street Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 06-20-2014, 05:54 PM   #1
Question
linoleum, laminate or what--Bourbon street laminate
I have a small rental. I needed to replace the linoleum in the kitchen. I was talked into a fairly expensive "floating linoleum that is not glued down or attached to the floor. I was told it is indestructible.
The first time I tried to move the refrigerator, it tore the begolly out of the linoleum--like shredding paper. The floor store said I should not have moved the refrigerator, that it "torqued" the linoleum.
Now I have always cleaned behind the frig and stove in my kitchens and I have never had this happen. The sales man says he never cleans behind the frig and stove and that I should have used a dolly to move the refrigerator. I am a single 65 year old woman and I am supposed to use a dolly to move my appliances to clean???
So now they are suggesting that I replace the linoleum with a laminate flooring, made in China, under the name Bourbon Street and they will do it for an additional 100.00.
I can find no reviews of this product on line--anyone know it? I am afraid I might get stuck with subquality materials that will last a couple years and need to be replaced. How do I figure out the quality. The warranty does not include sliding heavy objects over the floor.
What should I do--my rental is sitting empty until I can decide what to do. Thanks in advance.
RuthPa is offline   Reply With Quote
Old 06-20-2014, 05:59 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
Do not use laminate in a kitchen in a rental. The core is particle board. It will swell up and/or disintegrate with moisture. If you put in more vinyl, get some of the Teflon slides to go under the fridge. I have used those for years to move appliances on vinyl. Never tore one.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-20-2014, 07:44 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
If you do laminate don't go cheap Charlie route Which this no name brand is. You want a 10mm grade laminate from Armstrong or good name brand, they make them now more resistant to water. You would be able to put the stove and refrigerator over it.
JetSwet is offline   Reply With Quote
Tags
bourbon street , laminate florring , linoleum
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Can you run laminate over old linoleum glue? Player Flooring 13 06-23-2010 04:16 PM
Laminate flooring over linoleum and particle board no_spare_time Flooring 3 06-08-2009 12:54 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Laminate over linoleum? FindingNemo Flooring 6 09-20-2006 12:27 AM
