Lino Repair - Flooring - DIY Chatroom Home Improvement Forum
Old 03-04-2015, 10:25 AM   #1
Solutions (handyman)
Rewards Points: 488
Lino repair
I've installed lino before but usually on a new build or total floor replacement. A retirement home that I am doing some work for, ask if I could repair some raised lino. It is a small area about four feet by two feet. The lino in under a window that also has an electric heater or radiator running the length of the window (4'). The lino under the area has swollen and it looks like a couple of waves running paralel to the window. The lino itself appears flexible but must be about twenty years old, ... or more. Is there a proper way to loosen the wavy section and re-smooth it out? I think I can gently fold it back, clean the sub-floor and re-glue the area but would like some professional advice. Thanks.
Mark Harvey is offline   Reply With Quote
Old 03-04-2015, 10:29 AM   #2
Rewards Points: 18,384
Makes me wonder if there's a window or wall leak in that area causing the glue to release.
Old 03-04-2015, 11:11 AM   #3
Rewards Points: 488
Joe,
I think that was the case. The building is run by a foundation that is financed by the government. Needless to say, funds are very limited and this is why they want a repair rather than replaement. Not solving the problem, but i am trying to add a good bandaid.
Old 03-04-2015, 02:23 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 400
If you are very, very careful, you may be able to use a heat gun to loosen it and flatten it out.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
The Following User Says Thank You to rusty baker For This Useful Post:
Mark Harvey (03-04-2015)
Old 03-04-2015, 04:24 PM   #5
Rewards Points: 2,906
I'd try putting a towel over the wavy lino and iron it with a steam iron set on it's lowest setting.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
The Following User Says Thank You to Nestor_Kelebay For This Useful Post:
foundation Repair Questions njhammerman Building & Construction 8 02-13-2014 08:18 AM
The repair is "The Bomb" tenzo HVAC 3 06-27-2013 11:04 AM
questionable flange repair adcoje Plumbing 7 06-24-2013 10:26 AM
Req opinions on professionally completed drain repair. Mig3 Plumbing 8 05-19-2013 01:53 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
