Leveling Subfloor.. How To Do It?? (2nd Floor) - Flooring - DIY Chatroom Home Improvement Forum
Old 09-03-2015, 03:30 PM   #1
Rewards Points: 224
leveling subfloor.. how to do it?? (2nd floor)
one of the rooms i'm looking to remove the carpet and lay down flooring for is used to be an porch area (2nd floor) that is now enclosed. What the previous owner did was to simply install plywood over the existing joists and cover it up with carpet. The problem is that the old porch is sloped away from the house and one can really feel the sloping. I'm hoping to turn the room in to a bedroom and don't want any of my guest sleeping on a slope. I'm now left with the task of leveling the sub floor and I'm not sure how to attack it.
my considerations are:
1. left all the plywood and install angled pieces on the joists to level the floor? pros: prob the proper way to fix this. cons: a lot of work to lift the plywood
2. use self leveling mix to even out the floor? (
). pros: easy cons: really concerned about weight and potential long term issues. also I'll need another layer plywood to lay hardwood floors on top making it too thick.
any suggestions on what's the best way to get this resolved?
vote4Pedro is offline   Reply With Quote
Old 09-03-2015, 03:50 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
That depends on the slope. SLC can get pretty pricey in larger areas. Some can go over gravel to cut down on the amount used, though not sure on that over plywood which BTW may need lathe as well depending on the nmanufacturer. If its more than an inch or so at the far end I would be pulling the plywood and sistering the joists to level.
iminaquagmire is offline   Reply With Quote
Old 09-03-2015, 03:51 PM   #3
Retired Moderator
Rewards Points: 7,174
Simple, cheap and right----remove the plywood, exposing the floor joists.
Sister in new 2x6 (or 2x8) along side of the old floor joists---installing them level.
Put down new 3/4" subfloor.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ChiTownPro (09-08-2015), JazMan (09-03-2015)
Old 09-03-2015, 07:06 PM   #4
Rewards Points: 224
by sistering the joists. the new piece of 2x6 will be level... right? meaning the old joist and the sister joists won't be perfectly parallel??
Old 09-03-2015, 07:15 PM   #5
Property Mgt/Maint
Rewards Points: 6,548
yes, you got it
[political signature removed]
Yodaman is online now   Reply With Quote
Old 09-03-2015, 07:17 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 750
Hi Pedro,
Yes of course, that's why you're doing this.
No, they will be parallel, cuz the new is attached to the old slopped joists.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 09-03-2015, 07:32 PM   #7
Property Mgt/Maint
Originally Posted by JazMan View Post
Hi Pedro,
Jaz
if the new and old joist are parallel then the floor will still be unlevel,
Old 09-03-2015, 07:38 PM   #8
Rewards Points: 224
think we are saying the same thing jazman. the old joist will be parallel to the new 2x6. However the new 2x4 will not slope meaning that at 1 end, it'll be higher than the old joist.
another question on the new 2x6 is whether i'll need to run it end to end resting on the frame or can it just start 1/3 of the way of the old joist and not rest on anything?
Old 09-03-2015, 08:22 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 750
Pedro,
How much slope is there in the total run?
May be best to sister the entire length otherwise you may create a small valley.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
oh'mike (09-03-2015)
Old 09-03-2015, 09:02 PM   #10
Rewards Points: 224
probably about 1-2 inches. I can't think of a good method of how to measure how much i need to level at the ends.
Old 09-04-2015, 06:15 AM   #11
Retired Moderator
a string line helps---
I often use a 2x tacked to the wall--sort of a 'height stop' for the new joists--
Oso954 (09-04-2015), Yodaman (09-05-2015)
Old 09-04-2015, 01:00 PM   #12
Rewards Points: 144
+ 1 And run them the full length .You don't want a spongy edge.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
oh'mike (09-04-2015)
Old 09-07-2015, 09:43 AM   #13
Rewards Points: 224
I have to revisit this again. after pulled away the carpet, seems like lifting the subfloor is not an option as it's sandwiched under the walls. cutting it would be ALOT of trouble.
I'm considering just laying another subfloor on top to level it. it'll need to be precision work to get it level. another option is to use the self leveling concrete idea.
damn it jim, why can't it be easy. do i have other options?
Old 09-07-2015, 10:34 AM   #14
Rewards Points: 224
also took some detailed measurements. since it's a porch before, it's sloped not just towards the outside of the house but also to 1 side.
so length wise, i need to go from 3 1/4 inches to 2
and width wide i need to go 2 inches from joist to joist
FAWK....
Old 09-07-2015, 04:36 PM   #15
Rewards Points: 4,434
If this was a converted porch and they only covered the roof for a floor.?
I would be concerned if the new acting floor joist is sound enough for your intended purpose.
ron45 is offline   Reply With Quote
Carpet in the basement Packer Backer Flooring 17 11-30-2018 02:10 AM
Engineered hardwood over vinyl tile - am I being unreasonable or am I getting screwed photopeter Flooring 25 02-01-2014 11:41 AM
Leveling a concrete floor in converted den? WNB Flooring 0 08-20-2013 11:31 AM
Options to floor leveling compound for concrete repair. akimbo Concrete, Stone & Masonry 0 07-26-2013 10:20 PM
Garage Floor leveling. Marsharo Remodeling 1 12-30-2005 02:11 PM
