Leveling A Floor Drain In Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 07:59 PM   #1
Leveling a floor drain in basement
Can we level a floor drain in our basement ? Remodeling and making the laundry room into a bedroom, we already have a walk in shower
Jeannean is offline   Reply With Quote
Old 07-07-2011, 08:31 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What do you mean?
Are you saying you want to abandon the floor drain and raise the floor around the drain to make the floor level?
XXX
Old 07-07-2011, 10:18 PM   #3
Floor drain
No we'll keep the floor drain but we would like to put a little sink in but with the floor not level it would be difficult to place one in the area where the floor drain is
Old 07-07-2011, 10:23 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
O-k-a-a-a-a-a-y! Ah, uhm, ah, I sense a contradiction here.
How about a wall hung sink? Do you want a sink? Would you like a sink? What color is your automobile?
XXX
Old 07-09-2011, 12:39 PM   #5
The floor drain is only for overflow in case of flooding so putting in a sink is a separate issue ie: the sink drain will be plumbed into the sewer line, not the floor drain.
You can level the floor around the drain with mapei tri/patch or equivalant but first increase the height of the drain by glueing on an extension pipe so you have something to level to and a proper opening to place in a cover (never know when you want access to the drain)
*note, if this is the only drain then any flooding will cause both greater damage and could place into question insurance coverage......
HarryJ is offline   Reply With Quote
How best to dehumidify basement? peleliu HVAC 0 07-27-2009 09:55 AM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 06:38 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 12:21 PM
Leveling Basement floor Calm_Blue_Ocean Flooring 3 01-03-2008 05:19 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
