Legal Joist Size - Flooring - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree7Likes
Old 08-05-2019, 04:24 PM   #31
Rewards Points: 2,644
Re: Legal joist size
Stairs to the attic built over the existing and 6' dormer for landing and a hall? Rob 3' from kitchen? Raise the entire back roof? Common in nj and only twice the work.
Nealtw likes this.
carpdad is online now   Reply With Quote
Old 08-08-2019, 04:29 PM   #32
reallylongnickn's Avatar
Rewards Points: 32
New attic pics:
Attic door, 5" I suppose it was originally 6" but dried out over the years.
https://beta.photobucket.com/u/reall...1-e117ff279d25
Attic joists are 4"
https://beta.photobucket.com/u/reall...1-d096abb4b108
Joists are 18" apart
https://beta.photobucket.com/u/reall...e-0185249242a5
Dicks left plastic on some insulation bundles.
https://beta.photobucket.com/u/reall...9-3bd8780fc119
It was hot up there...
https://beta.photobucket.com/u/reall...d-941a3f1b2b4a
reallylongnickn is offline   Reply With Quote
Old 08-08-2019, 04:39 PM   #33
retired framer
Rewards Points: 20,658
I bet that was good
reallylongnickn likes this.
Do not use flat bottom gables with scissor trusses.
Old 08-08-2019, 04:54 PM   #34
HenryMac's Avatar
Rewards Points: 1,002
Two things about spiral staircases:
1. They suck as far as carrying anything up the stairs.
2. They give the illusion of saving space but actually don't.
I was toying with using one to access the loft in my barn. I ended up building a regular set of stairs. What I found out was after it was built the area under the stairs is great for storage. I actually gained space due to the dedicated storage.
HenryMac is offline   Reply With Quote
Old 08-08-2019, 04:55 PM   #35
retired framer
Originally Posted by reallylongnickn View Post
New attic pics:
Attic joists are 4"
So to use the center of the building for a room you have to new joists from the center to the outside wall, if the main floor is 2x8 that should work upstairs to, You would have to stay as close as you could to 16" on center for 2x8. but if you want to cut a 5 ft square hole in the floor You would likely have to use 2x10 for joists. Then you could stay with the 18", that would just waste some plywood but save on joists.
Old 08-09-2019, 04:20 PM   #36
Rewards Points: 32
If I was in the field of construction, I would think this is a dumb Q, but...
So the 2x4's cannot be parallel beside each of for strength right, the 2x4's must be replaced with either 2x6 or 2x8 as you stated?
@HenryMac , those stairs don't appear to be overly steep either
Old 08-09-2019, 05:27 PM   #37
retired framer
You would leave the old there so you don't loose the ceiling but the 2x4 are not a floor.
Old 08-09-2019, 06:51 PM   #38
HenryMac's Avatar
They meet code in regard to run/rise.
