Leave It Be Or Keep Stripping? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-16-2018, 08:15 PM   #1
Rewards Points: 164
Leave it be or keep stripping?
I rented the floor stripper from HD and managed to rip up most of my 25 year old vinyl flooring. There is still mixture of stripped to concrete and a having a really thin layer of the backing material still stuck on. It's a very thin layer, less than 1/16".
I'm thinking I should scrape any lose bits up, but the mastic will make up the difference as long as it's firmly stuck to the floor.
Is there any good reason I should kill myself getting down to bare concrete?
andr0id is offline   Reply With Quote
Old 09-16-2018, 08:25 PM   #2
Guapo
Rewards Points: 11,950
Re: Leave it be or keep stripping?
By floor stripper, did you mean a rotary buffing machine? If so, what did you use with it? For example, a black pad, stripper with water & ammonia, Red Devil Lye, etc...? What are your plans for the floor once it's done?
Guap0_ is offline   Reply With Quote
Old 09-16-2018, 09:03 PM   #3
Rewards Points: 164
No, a big heavy machine with a large vibrating knife at the front.
I will be putting down ceramic tile.
Old 09-17-2018, 07:31 AM   #4
Guapo
I don't know if the remaining glue will hinder the new adhesive. Why don't you see if you can find a chemical that will dissolve the glue? Usually something oil based works. The rotary machine that I mentioned may work.
Old 09-18-2018, 08:20 PM   #5
Rewards Points: 4,434
ron45 is offline   Reply With Quote
Tree stump grinding / leave wood/chips or remove? nutshellml Landscaping & Lawn Care 3 03-17-2016 06:01 PM
leave gap between concrete pavers? bdclayton76 General DIY Discussions 5 06-26-2015 08:54 AM
How much space to leave around windows? MarcM Building & Construction 14 09-26-2014 08:23 PM
Old Phone Cord - Leave in wall? mklaman Electrical 8 04-16-2014 12:16 PM
How much wire to leave in box? Nhrafan Electrical 7 04-13-2007 04:03 PM
