Laying Tile Over Concrete/OSB Seam - Flooring - DIY Chatroom Home Improvement Forum
Old 01-28-2014, 03:45 PM   #1
Want to Learn
jonhayden's Avatar
Rewards Points: 157
Laying tile over concrete/OSB seam
Hi all,
I recently added a bedroom in my basement. I did all the work myself and passed all my inspections. The only thing I didn't do was the carpet install. If you look at the picture, the carpet was laid all the way to the edge of the wall instead of stopping at the center of the door. I can only blame myself though because I asked him to do that even though he told me you typically only go to the center of the door. So now that I'm working on the adjoining bathroom, I see why it should stop at the middle of the door. I don't want to see the bedroom carpeting from the bathroom. I want to now remove some of the carpet so the tile can go all the way to the center of the door. If I remove 2 inches of carpeting, it will expose 2 inches of the OSB subfloor. Luckily, the Self Leveling Compound I just poured for the bathroom is the exact height of the OSB subfloor. So my question is, can I put tile across the seam and on to the OSB? If it's possible, do I need to do something to the OSB before I put thinset on it? My other solution would be to just put in some kind of threshold so it isn't so obvious I screwed up.
Also, along the same lines, in one spot, there's about a 1-inch gap between the SLC and OSB because the sill seal I used to block the SLC came out too far. Can I just fill that with the thinset I use to lay the tiles?
Thanks,
Jon
jonhayden is offline   Reply With Quote
Old 01-28-2014, 03:58 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,652
OSB on a concrete floor under carpet and ceramic tile? Why?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-28-2014, 04:03 PM   #3
Want to Learn
jonhayden's Avatar
Rewards Points: 157
Sorry, maybe I'm confusing in the post.
The bedroom is a layer of Delta FL, a layer of OSB, and carpeting.
The bathroom is a layer of SLC (containing heated flooring wires) and a layer of tile.
Is there something wrong with that? My question is if I remove 2 inches of the carpeting, I'll have 2 inches of OSB exposed that needs to be covered. I would like the tile from the bathroom to cross over and sit on the 2 inches of OSB that's exposed.
Old 01-28-2014, 04:52 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 750
You should remove 4.5" of carpeting and Delta FL. Build up to threshold area as necessary and then install a 4.5" wide marble threshold in the jamb. That's the right way to do this when it's a bathroom doorway. Stoping under the door is for regular room-to-room transitions.
Do this, except use a 4.5" threshold; http://www.google.com/search?q=doorw...42%3B600%3B403
Not this; http://www.google.com/search?q=doorw...ml%3B550%3B413
Otherwise do this;
Jaz
Laying tile over concrete/OSB seam-100_1164.jpg
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 01-28-2014, 05:01 PM   #5
Want to Learn
jonhayden's Avatar
Rewards Points: 157
Gotcha. I'm just leary about trying to cut out the OSB. I was just going to do what the builder did in our master bath/master bedroom transition:
Is that wrong what they did? I know my last house had that kind of a transition too.
Old 01-28-2014, 05:43 PM   #6
Want to Learn
jonhayden's Avatar
Rewards Points: 157
Oh, I should mention that the door between the bedroom and bathroom is a pocket door so if I did a 4" marble threshold, you'd see and inch stick out from the bedroom I think.
Old 01-28-2014, 06:14 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 750
Yes of course, you're supposed to, the threshold goes in the jamb.
But, in some areas of the country they use skinny thresholds especially in southern states and in motels where steel door jambs are used. The end results is ending the floor coverings like it were a bedroom to hall situation.
Other places where real "mud" work is done, we use a threshold the width of the jamb. The marble has several purposes. To give you a straight edge to cut to and since the marble is placed about 1/4" proud of the tiles, it creates a small dam to help keep overflows from reaching the other room as fast. Another benefit is since the marble can be seen from the hall, it helps identify the bathroom when the door is closed.
Although I sell marble threshold to stores and distributors (full containers imported from italy), I actually recommend skipping the threshold for appearance sakes. As in my pic in post #4 above.
Jaz
Old 01-28-2014, 06:58 PM   #8
Want to Learn
jonhayden's Avatar
Rewards Points: 157
Ah, okay, I understand. I like the picture in your post. And those are similar tiles that I'll be using. I like the 12"x24" tiles. Thanks
Old 01-28-2014, 09:21 PM   #9
The carpet will wear out along that edge. Tack strip should never be across a doorway.
How to remove single 18" ceramic floor tile hkeiner Tiling, ceramics, marble 8 02-28-2013 09:56 AM
Laying hardwood floors over plywood and tile in a mobile home chrismarx Flooring 3 04-15-2012 04:55 PM
laying stamped concrete over old tile Kimmarie Flooring 24 03-20-2012 12:20 PM
Laying tile jaekim Flooring 5 08-26-2011 03:32 PM
How to figure out where to start in laying out tile cheryldtrixie Tiling, ceramics, marble 3 06-01-2009 11:49 AM
