Laminated Flooring On Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 07-31-2015, 10:59 AM   #1
Rewards Points: 278
Laminated Flooring on Concrete
Hi all,
So, I'm finally working on the flooring for my basement. The concrete is flat enough and I've decided to go with laminated floor.
My basement doesn't have moisture issue since I have tested several times on several areas.
I understand that I need to place a vapor barrier first, then padding, and finally the laminated floor.
For the vapor barrier, do I need to tape it onto the concrete? If yes, what kind of tape is good for such application?
Is there any recommendation for padding?
Thanks!
325_man is offline   Reply With Quote
Old 07-31-2015, 01:54 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 400
You need to do whatever the manufacturer suggests. Most won't warranty laminate below grade.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-31-2015, 04:00 PM   #3
Rewards Points: 1,042
Most manufacturers allow engineered flooring below grade, better than laminate anyway.
Canarywood1 is offline   Reply With Quote
Old 07-31-2015, 04:17 PM   #4
Rewards Points: 18,384
Just not going to find many fans of Laninate floors in general from any of the pros, here or on any DIY website.
We've all seen what happens from just to high a humity, a simple dog bowl sitting on it, sump pump failure, using it in a bathroom.
Old 07-31-2015, 05:31 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 780
Can you tell use exactly which product you plan to install?
What tests have you performed several times?
Does your basement have a sump pump?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
vapor barrier and flooring on slab concrete cbrowers Flooring 5 02-03-2012 10:20 AM
Below Grade Bathroom Addition (Concrete / Flooring Question) cmremmert Building & Construction 1 07-12-2011 07:16 AM
Installing engineered hardwood flooring over concrete deborahs Flooring 3 07-30-2009 10:35 PM
laminate wood flooring over concrete janet.giron Flooring 3 07-28-2009 05:47 PM
Concrete alb preparation for Laminate (click together) flooring SJC Flooring 1 02-06-2008 03:16 PM
