Laminate Transitions - Flooring - DIY Chatroom Home Improvement Forum
Old 12-03-2013, 12:59 PM   #1
Rewards Points: 118
I am installing a laminate floor, I have one transition where the laminate will be installed in two rooms and run the same direction (the two rooms are next to each other). There is a 36" door way separating the two rooms. Do I use a T strip? I have only seen T-Strips where the narrow end of the laminate is in the doorway, in this instance the LONG side of the laminate plank will be in the door way.
How do I transition that?
chrisb75 is offline   Reply With Quote
Old 12-03-2013, 02:34 PM   #2
Rewards Points: 18,384
Still need a Tee strip.
Old 12-03-2013, 02:37 PM   #3
Rewards Points: 118
So I install it just as i would for butt joints?
Old 12-03-2013, 05:20 PM   #4
Yes. Same expansion and contractions rules still apply.
laminate floor transitions Gary Sutherland Flooring 1 07-07-2012 07:49 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
What do I do if laminate floor is too high for transitions to lino. agapediy Flooring 2 08-07-2011 05:53 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
laminate floor transitions m sharp Flooring 3 11-16-2006 09:53 PM
