Laminate Transition By Entry Door - Flooring - DIY Chatroom Home Improvement Forum
Old 06-18-2016, 04:58 PM   #1
Rewards Points: 60
Laminate transition by entry door
I've done a few laminate floors in living rooms that have an entry door. I've just used a standard T transition for laminate but it never really looks good, kind of looks out of place since the ends aren't really finished. At each end is just a square cut transition sticking up and it just looks out of place to me. Is there a better way or is this the standard for entry door transitions?
ponch37300 is offline   Reply With Quote
Old 06-18-2016, 08:57 PM   #2
Rewards Points: 17,912
Re: Laminate transition by entry door
Are you talking about where it meets the back side of the threshold?
If so what I've done right or wrong is left a small gap and used color matching caulking instead of the strip.
Looked far better and has not failed yet after a few years.
Old 06-19-2016, 10:55 AM   #3
Rewards Points: 60
Yep the threshold sticks up above the floor. The T molding they say to use is too wide and looks out of place. On each end it just stops and doesn't look good. I was thinking about this a little more and wonder if making your own would be the best option. Make an L trim out of a matching wood. It would only have to be about 3/4" to 1" wide and you could even angle or round the corners on each end of it to give it a more finished look. Shouldn't be too hard with a router and table saw.
Old 06-19-2016, 12:00 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 638
Shoe mold or 1\4 round glued to the threshold.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Installing an above grade - basement entry door. EvilBetty Windows and Doors 4 12-31-2014 10:53 AM
Replacing Prehung Front Entry Door in Stucco a1481155 Windows and Doors 13 09-04-2013 05:11 PM
New Entry Door + Old House = Grrrr garso22 Windows and Doors 16 11-26-2012 10:07 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 11:23 AM
